Oil report...headgasket!
north carolina
Well it happened...First I find rot in my wheel well seat belt bolt where my son sits. Good news is my boss will fix it for free. In the meantime for s&g I sent out my oil to be checked and sure enough I have some coolant leaking into my oil. Or at least I think I do. My report says that their is Potassium in the oil and that Delo doesn't contain Potassium. Does anyone know if Mobil high mileage oil does. I may have topped of my oil withing 1k miles of changing it with a quart quart and a half of mobil high mileage oil could this be the cause of the potassium? If I read the report right avg. Potassium is 58 and I am at 90. How high is this really? Could a quart quart and a half throw these numbers off?
ts been a real depressing week for the LX
Edit to add I read it wrong. I am at 90 and the avg is 3!
If in a bind and short on cash and time, I have used Bluedevil Head Gasket Sealer 38386 | eBay
in a Ford work truck two years ago. This truck was burning about 2 gallons of AF/week. Truck is still running strong with no issues today.
Sorry about that, but knowledge is power. Glad you got the analysis. I hope the other measures on engine health looked good.
Some people on the forum have had success with Bars Leak 1111 so I ordered that at 4am lol.
It just keeps getting worse. I did rear brakes a couple weeks ago so I don't know if it is related but I felt like although the car was functioning properly the rear discs were getting hotter then usually. I say that having never really paying attention to how hot they got before I changed them. Well on my way to work this morning at about 30 mph it sounded like a balloon popped by my driver rear tire. There wasn't anything in the road, the car didn't function any differently after but it was loud......maybe I need to start another thread about that!!!!!
I drove this truck flawlessly for 9 months and 15k miles...looks like it turned into a parts truck overnight!!!
Don't be a drama queen :flipoff2: It's an old truck and it will require upkeep. Mine ran like a top when I bought it and needed about $2k in PM within the first 6 months of ownership. Just keep things in perspective.
haha.
Honestly I would be fine, well not fine with all this if it weren't for the rust issue.
The truck will need a cat back exhaust soon, rear shocks and some other minor PM on top of the now needed head gasket. I have a hard time justifying that amount of cash on a rusty truck.
I have a complete new unused Bosal catback exhaust that you can have for $200 + shipping if you want it. PM me if interested :)
How bad is the rust? I have given up on a truck (my first 60) because the rust was beyond my ability to fix, but it was really bad--holes everywhere. My LX is a little rusty, but just enough to remind me not to take it too seriously :D
Does anyone know the real difference [benefit] of using bars leak pro Vs. 1111? their website says use pro if you car can run 15 minutes without overheating, use 1111 if it can run 20 minutes. Mine doesn't overheat at all so I am assuming my issue isn't "that" bad??
The bars leak didn't work on the ford pickup I mentioned earlier. Hope it works with yours. If not, Blue Devil is the fix. I've used several Blue Devil products with amazing results and the crazy thing is all of the products I have used are crystal clear like water.
To answer the question above about how much Potassium you might see with Mobil 1 10W-40 High MIleage, I got a level of 6 ppm Potassium recently using mostly Mobil 1 10W-40 HM (6 quarts Mobil 1 10W-40 HM with 1 1/2 quarts 20W-50 Mobil 1). Using Mobil 1 oil of different viscosities over the years the Potassium levels I've gotten ranged from 0-2 ppm.
Dumped Bars 1111 into radiator and ran it per instructions. Will do an oil change tomorrow ten another one 1k miles or so after and send out another sample and see what I have.
The 1111 looks like think melted copper.
Drove about 100 miles after dumping in the bars leak, should i still see the copper color pieces of bars floating around when I pull off the radiator cap? I followed the directions exactly except I must have over filled the Radiator a bit as I had some coolant come out the over flow.
Also temps stayed hotter then usual but that could be a product of an overfull system no?
I called Bars leak and they said seeing the copper color in the coolant is normal as it could take a few cycles to fully bond to any issues on the head gasket. When I got off the phone I realized I forgot to ask about the heat.
I had just done the 20k fluid mod in the fan a couple weeks ago that brought the temps down around 185 while I drove around. If I got the truck real hot lugging it around town with ac on and it hit 199 the fan would kick on and drop it right down to 185.
After adding Bars Leak its as if the fan is doing nothing. The truck is always over 190 If I stop in traffic it hits 199/203 pretty quick then just hangs there never getting hotter. The fan will maybe drop it a degree or 2.
When I added the bars leak I topped off the fluid and I think I added to much as I lost some out the overflow tank. My heat blows great but could the truck running hot have anything to do with needing to be burped or if I had air in the system would the heat not blow hot?
It sounds like the radiator isn't cooling like it was before adding the Bars Leak. If the fan clutch is engaging like you mentioned, the temps should go down to pre Bars Leak condition. You could burp the system, but usually when the coolant system becomes air locked, your temps go up way too fast and you would never be able to drive it very far. Burping it could be worth a try though, it's free.
Did you drain some coolant before putting the bars leak?
I use the bars leak with carbon fiber in mine and haven't have any issues, my Temps still normal but they always were. I am now collecting parts for a head gasket job, I'm actually pretty excited cause once I do this job the truck should run great for awhile. Don't get discouraged and try to enjoy it, you are driving and old truck but the most important, a landcruiser 80!
I have some rust too not much we can do.
I did take some coolant out before adding bars. I think I was low but still took some out anyway and then when I topped it off i think I added a bit to much.
The rust I have is in a spot that's a safety issue I need to see how well that repair goes. I wont be dumping a ton of money into this truck it just isn't worth it to me [given its condition] It would better serve someone who will actually take it on trails etc.
The 401 code popped up again today and I know it is related to my charcoal canister so add that to the list.
Pretty soon look for the thread "What is my 97 LX worth":)
Edit to add I got a quote from the shop I work in 170 for a Koyo radiator. But am also thinking my new T stat could be gummed up now too??
Seems like your mind is made of already, a lot of people go thru this, once they start having issues they don't think Is worth it, if you stick with it over this few bumps you love it. (at least that's what I tell myself lol)
Do a search on the resistor trick for the p0401 code. It will remove a LOT of stress from your life. Mine passed inspection last week with that mod.
Definitely try burpin the system. Hopefully that will find a pocket of air, and resolve your problem. If not, the bars could be clogging up coolant passages, reducing the efficiency of the system.
Good Luck.
