'77 2f / FJ40
First I used two tricks learned from this board to make a couple jobs easy.
1) the carriage bolt / socket press idea to get the pilot bearing race out
2) the bottle jack / 2x4 against the side of the oil pan to get the pan unstuck
Both worked awesome...so THANKS!
My question is now that I have the pan off (to replace gasket / leak at rear) Should I replace the oil pump while I am in there? The engine had no oil pressure problems that I am aware of but this is new 40 to me and the oil looked like mud. Is there any way to check for wear and are oil pumps something you all would replace in this situation? I dont want to spend $ if I dont have to but I also dont want to take the pan off again
Thanks,
Alex
Thanks,
Alex
