cruiserpatch
Supporting Vendor
- Joined
- Nov 24, 2020
- Threads
- 138
- Messages
- 1,368
- Location
- Atlanta, Georgia
- Website
- www.cruiserpatch.com
Disconnect upper ball joints on both sides (one at a time is probably easiest) and remove both CV axles. Easiest method is to turn the steering wheel all the way to one side, pop out inner joint first then slip the axle down through the LCA.Thanks! Any tips as to how far I would need to go to get the diff out? I'm guessing the wheel hubs will have to come off the spindle. Possibly remove IFS as well? I couldn't find anything on youtube about how to remove the entire front diff.
Once the axles are out you can unbolt the front diff and drop it. Drain the oil before doing so
