Oil Pressure Gauge
Olympia, WA
Hi,
I have a oil pressure gauge that isn't working at all. I bought a new sending unit from Cruiserdan and installed it and the gauge still doesn't give any reading. I noticed about a week ago that the needle deflected all the way to the uppermost limit and then dropped to zero causing me some concern. I reasoned that the pressure must be fine given the erratic needle movement.
Does this sound familiar to anyone. I did a search and didn't come up with much.
BTW, the wire at the sending unit has broken from the connector. I have the wire held in place. Is there anywhere that I can get another similar connector?
I have tested the gauge by grounding the sending wire which causes the gauge to read full deflection (high oil pressure).
Thanks in advance!
Remove the thread sealant on the sender, so that it can ground to the block, and figure out a new connector for the lead.
Go to the junk yard and find a Toyota car or mini truck from pre 1995 for sure and cut the lead to the sender and splice it into yours....it should have the same push-on style lead to attach to the sender.
Good luck!
-Steve
Thanks, Steve. I actually didn't assemble it with any thread sealant; just metal to metal. Do you think that the gauge could be bad? I understand it's not that hard to fry 'em.
I had to replace the guage a few years ago. That solved the problem.
Thanks CruiserDrew. It's kinda like I thought. The weird thing is that the gauge will read to full deflection when I ground the sending wire leading me to believe that the sender was bad but with a new sender in it and the gauge still not working, the only recourse is to replace the gauge. I just hate throwing parts at it until I find the real cause.
Before I put any more money in it, I would pull the instrument cluster and the harness plug off the back. Then I would take an ohmmeter and clip one end to the wire that attaches to the sender (pull wire from sender), I would touch the other wire from the ohmmeter to the frame. If it shows continuity then your problem starts with the harness wire. If it is the harness wire grounding to the frame somewhere, you will need to fix the ground or replace the wire (no big deal). A deflection to the upper most limit can be caused by a grounded sender wire. When that happened, it may have wasted you gauge. So regardless of what you choose to do, it is in your best interest that you have confidence that the sending wire is not grounded somewhere along it’s path.
Edit: You will want to move/pull on the wire in case there maybe an intermittent short. I've had one short that turned out to be behind the dash and was due to the harness laying against one of the metal supports. This was caused by time, age and vibrations. You may want to move the harness around behind the dash. If there is no continuity, that’s a good thing. While you have the cluster out, check the traces to make sure none of them are damaged/burned out. The next thing to check is both ends of the sender wire for continuity (cluster connector to sender connector).
Thanks for the info!
