ok... well oil was not getting to my head... I have pulled it and found that the head gasket is on correct... ran some air down the oil hole in the head and also in the rockers... both seem to be working... all holes line up correctly...
I pulled off the distributor today... hooked it up to the 18 volt drill.. got oil to pump to the oil filter... put that back on and was not able to get oil to go to the top of the head... so I am thinking my oiling problem has somthing to do with the block and not the head, as i previoulsy thought..
Talked to my old man and he said somthting about the Cam Barings not line up correctly and blocking the oil hole. ( not sure this is what he said but that is how I took it)
does any one have thoughts...............
Thank you!!!!!!!!!
Thank you!!!!!!!!!
