My buddies 82 with 22r has a leak out of the timing chain cover, it appears to be coming out of where the pulley attaches to the crank. I'm curious if this is just a rubber seal that went bad or what as I'm not very familiar with the 22r engine.
Yes, there is a rubber seal behind the pulley. It's just like the rear main, only smaller.
You may want to get a oil pump o-ring also, might be leaking there instead/also.......
