Oil Leak
Puyallup, WA
First post here, I have a new to me 1995 fzj80 with just a little over 200k miles. It just recently started dripping a few drops of oil onto the driveway. It's coming from the front, dripping onto sway bar and then finally to the ground. Nothing serious I don't think. I'm thinking maybe it's time to replace the oil pump seal or just add more oil? I plan to wipe it down so I'll have an easier time tracking the leak but maybe some of you gurus have seen this before. Here are some pictures for reference.
Oil there could be coming from a number of locations and always keep in mind that oil runs down and back on these engines. Best approach would be to clean / degrease the engine top and bottom and then monitor for leaks starting at the top and front of the engine. Valve cover gasket, oil pump cover, distributor o-ring, etc. etc. could all be contributing to what you are seeing or it could be coming from lower spots.
Some leaks may be easier to see in daylight, many are easier to spot with a good flashlight in lower ambient light in my opinion. Once you get things clean and then start checking for the leak sources you should be able to find the worst leaks pretty easily.
@jpoole is spot on..... Start with the main three and then reevaluate:
Valve cover gasket
Oil pump cover
Distributor o-ring
Unless you are sure these have been done recently its very likely they are leaking.
Alright thanks guys, I have quite a bit of cleaning to do. I'll keep an eye on oil levels for now until I have some time set aside to really get after it.
I replaced every gasket recommended in this thread except the timing chain seal and the rear main seal. Timing chain is an intrusive and intensive gasket job that should get done should you ever have to rebuild the engine (per my shop). Rear main seal is also a larger job so I passed on it as it was only weeping (no oil drops on floor).
Rear Main "while I'm in there"
Hey thanks for the link!
Valve cover gasket
Oil pump cover
Distributor o-ring
My first guess would be valve cover gasket. When I went to replace mine the screws toward the back of the engine were only finger tight!
I've tried many different engine degreasers with little success in cutting through two decades of Land Cruiser Valdez oil leaks. The best solution for me turned out to be a "Big Blast" can of WD40. Pretty much hosed the things down, gave it some time to penetrate, then hit it with a pressure washer. The WD40 really cut deep into some of the most stubborn sludge. For what it's worth.
