Oil Leak...Fuel Pump?
Colorado
I have cleaned my engine (F) to locate my oil leak.:) It appears to be leaking from the fuel pump(mechanical). Logic would say...replace the gasket and all is well, right? :crybaby:
I did all of this and the leak is continuing, just as bad as before. What gives? On a somewhat thorough cleaning, I saw no damage to the pump, but once the engine is running, I get a fairly steady stream of oil from the pump area, dripping down on the plate below. Could the pump housing be cracked? Have any of you seen this? Where can I source an OEM pump for my '71?
Poser
Oh...Durka Durka Durka.
s-Moderator
Supporting Vendor
MN
What Jeff said.
Don’t think OEM is available any more....
Marks off road should have a pump.
SOR will have a pump.
Napa may have a pump.
Carquest may have a pump.
:meh:
Colorado
Thanks Jeff and poser. That was what I was thinking too, but needed just to make sure. Got one ordered yesterday.
Did it leak all the time or only when the engine was under some strain? I've been trying to chase an oil leak that I thought was coming from the dipstick tube but given the location of the fuel pump, this makes a lot more sense. My oil is thin and smells like gas. Did your engine still run okay while this was happening? I thought if the fuel pump was leaking this much the engine would be running like crap but maybe not?
Thanks.
rsbcruiser
Portland, Oregon
Ya know Chris, Now that I think of it :doh: I just might have given you some incomplete advice. It is possible to get a gas smell in your oil from blowby. The blowby thing, one way to tell is to disconnect the pcv valve . Block the hose so you don't have a vacuum leak. Now start the engine and walk around to the engine. If there are exhaust gasses spewing out of the engine from where the pcv valve used to be then you have bad rings and or bad valve seals. If your engine is indeed making oil because the fuel pump is bad then you have lucked out.
Tasmania, Australia
On one of my 40s, on a steep decline the engine oil will leak.. The leak appears to be coming from the fuel pump.. I had another pump out for a cleanup and reinstallation on another engine.. I noticed when I washed it that there appeared to be a vent hole from the underside of the diaphragm through to the cam follower opening.. No idea why this is there, but would explain the oil leak as the engine is tilted, the oil runs foward in the engine, higher than the fuel pump and spills out this vent hole thing..
Spokane,Wa
The oil pump vent hole is there. Oil will run out at the right angle but shouldn't normally. Maybe a stupid question, how many quarts of oil are in there?
FJ40Jim
The Cruiser Whisperer
Lancaster, Ohio, USA
8 or 9 quarts, depending on pan, filter, oil cooler, etc...
The fuel pump contains 3 diaphragms.
The top two are the pumping diaphragms. If the lower one (23103) cracks, it will allow gasoline down into the bottom of the pump, which will wind up in the sump and leaking out the weephole.
The lowest, smaller diaphragm (23133) is the oil seal. If it is failing, it will allow oil out the bottom weephole, or allow water into the crankcase on a deep ford.
Tasmania, Australia
Well there you go.. Luckily my leaking one is sitting on a wreck in the corner of the shed and has no risk of water entry.. I've never had a fuel pump apart..
Are rebuild kits available for these?
FJ40Jim
Rebuild kits are available from Toyota USA, but the kit is more than the price of a new OEM fuel pump in an aftermarket box. IOW, if a person wanted to rebuild a 1977 pump, the most cost effective way to do it would be to buy a new Kyosan pump at Advance Autoparts, and remove the guts to use as a rebuild kit.
Yeah, somehow I don't think I'll be that lucky. I'm taking it in to the garage to have a leakdown test done. I'll keep my fingers crossed but I'm expecting the worse.....
Hugh Heifer
Hangin' in Virginessee.
Bristol, VA
Do the newer pumps work the same way?
After getting the Gazoo on the road I was fine and suddenly I started having a severe leak. I got :princess: to put it under load after it was nice and hot and I got a heck of a steady stream of oil from what appears to be a vent hole on the newer style pump below.
The screwdriver in the pic is pointing to the hole the oil was streaming from on the old pump.
Hugh Heifer
Bristol, VA
With lack of a response, tomorrow I will be replacing the angry pump with an aftermarket one. Wish me luck!
