OIL IN RADIATOR
Hey guys. Just wondering if anyone can help with an issue I'm having with my 80 Series. Okay, so here it is
I have had my 94 80 Series cruiser with 1fz-fe motor for 18 months now. Since I've had it, it's been getting oil in the radiator. But not getting any coolant in sump. Correct me if I'm wrong, but my guess is because the oil generates more pressure than the cooling system. Anyway, after getting sick of draining the radiator between services, I decide fed to start with the cheaper repair of the two. I removed the oil cooler and had it tested. Results came back fine. So I refitted it. Still got oil in the coolant. Next was the head. I sent it out and had it swapped over for a reman head with all valves etc. Fitted the new head, thinking the problem would be solved...
NOPE
After doing both the oil cooler and head, I'm still getting oil in the radiator. Now about the only thing left is a cracked block, right? So I was just wondering if it is fixable? Is there an additive product I can use to fix a cracked block? Only problem is that I'm not sure it'll even work because the crack would be in a gallery somewhere, and because the oil pressure is higher than the cooling system pressure, the oil will probably just push it out. Won't it?
Anyway guys, thanks for taking the time to read my post and a big thanks in advance for any help
you replaced the head? why with a reman? theres no guarantee that the reman was done correctly. Could have gotten a warped head, best thing to have done would have been to send your head off for decking and valve seals.
Also did you no inspect the block while the head was off? this is when a cracked block is usually noticed.
I got a head from a reputable supplier so I have no doubt it's okay. And I did check the block when the head was off and there was nothing visible. If anything it looked really good.
You are correct in that the coolant pressure should never go over 16 psi while the oil can go over 60 psi on cool mornings.
Are you sure it's oil and not transmission fluid? A leak in the radiator at the transmission cooler lines in the bottom tank can leak fluid into the cooling system. You will usually see water in the transmission fluid too. A friend ruined a transmission this way too.
Also, are you seeing a brown nasty milkshake develop in your radiator with a corresponding loss of oil on the dipstick? It is no small feat to completely clean out the old oil from of the cooling system. It requires many flushes with a cleaner (Simple Green or the like) and lots of clean water. If you don't see the oil disappearing from the crankcase, you may be seeing residue.
Our cooling systems like less pressure. The Toyota OEM radiator cap is set to relief at 12-13psi, most aftermarket caps are 14-15psi.
"I drink your milkshake" (from a movie that I cant recall)
Im dealing with similar issue in the top of the radiator.....
