I have oil in my coolant. I use very little oil between changes but it appears that oil is ending up in my coolant and then in my overflow bottle. It looks like a sludge.
More sludge appears if the engine runs at high RPM with high oil pressure. When I start the truck, the oil pressure gauge goes above the second mark in the middle, and when the truck just idles, the needle drops slightly below the first mark in the middle.
The HG was done at 90K and it appears to have started after that, but then again, I only bought the truck at 75K. The truck has 157K on it now and I would like to stop the oil getting into the coolant because it appears to damage all the rubber components. I don't think I even lose 1qt of oil between 5K oil changes. I use Mobile 1 since I bought the truck.
Last weekend I replaced all the gaskets in the oil cooler thinking that was the reason for the failure. I also replaced all the coolant hoses, so I would like to solve this problem before the hoses get damaged too much. As of now, I think I might still be getting oil in the coolant, but it could be left over sludge that was in the heater core as well.
There is no coolant in the oil nor do I have any other symptoms of a HG failure. There isn't oil leaking out from the side of the block but I think I am resigning myself that it is indeed a HG failure, a second for this vehicle.
The truck has a new radiator from Man-A-Fre (the Ron Davis Aluminum Radiator).
I assume a high pressure oil passage from the block to the head is leaking into a neighboring coolant passage. Is there only one of these passages or several? I suppose I could have a cracked head or block.....
Any comments or suggestions?
