- Thread starter
- #21
Also had to modify the slides, recline mechanism and slide handles.
The lock latch sits down near the "crotch" of the handle lever arm so it should be ok. I need a set of new cylinders eventually. I thought the bearing might prevent binding and breakage. My old handle broke, presumably from friction/binding.Your rear lift handle, what prompted the bearing mod? Did you lose the ability to lock? Good luck man, cool project!
I liked the original mustard yellow. Someone at some point did not, apparently. I don't know what they were thinking with lime green. I'm thinking dark brown or dark green with gray wheels, white top and white headlight surround. Thoughts?
anyway.The lock latch sits down near the "crotch" of the handle lever arm so it should be ok. I need a set of new cylinders eventually. I thought the bearing might prevent binding and breakage. My old handle broke, presumably from friction/binding.
So hopefully I get my one broken handle outta the way right now! Thanks for the tips. I think it's funny how my current paint job was taken as a camo design. Its just the green paint with primer sprayed over bare metal where I started doing bodywork to prevent further rust. Wasn't really going for any design or anything. HahaTypically the back hatch handle breaks where the notch for the lock is. While a pain loosing the struts before closing helps. Because the hatch rattles adjusting the catches tight is a must to reduce it. When opening pressing the hatch in with one hand and lift the handle with the other takes a lot stress of the handle. Forty-three years only broke one handle on my 68.
Putting my 2 cents in on color.
I agree with your thinking above.
To me the FJ40 looks best in one of the drab original colors that would look terrible on anything else.
The sage green in the picture you posted above is one of my favorites, T303 Fashion green?
Rustic green, Olive, Mustard, Brown.
That said, the lime green plus black blotches somehow looks cool as the basis of a paint scheme for something else.
Hey guys, I'm under the dash cleaning up the wiring and I'm stumped. What is this box? Smog computer? Ignition module of some sort? Voltage regulator? I don't see any markings but the plug is huge and looks important. Found it near the fuse block on the driver's side footwell. Couldn't find it on any diagrams, there's so many variations of the fj40!
Thoughts?
new wheels and tires, longfields and start on the drivetrain and suspension rebuild. Paint will be last. Check out the wheels and tires, oh hell yeah!Thanks guys. Yeah, they don't call it Trashganistan for no reason. An ANA soldier propositoned my buddy yesterday, so that was kinda funny. I'm saving some cash so I'll slap some
