Official ONSC member buying/selling thread
Built SOA Cruiser Axles FJ40 or FJ60 w/ Centered Rear
Ive got 1 ton axles I'm building for my cruiser and i need to get rid of my current setup. I had these on my FJ40, very strong axles. $1,850 for the pair.
I'm willing to separate.
Front - FJ60 axle widened 2.5" on the passenger side and will bolt directly to fj40 spring width (no outboarding required). 30 spline longfields inner and outer, lock-rit locker, 4.10 gears, fine spline pinion, pinion flange for multi toyota patterns, six shooter knuckles, arp steering arm studs, fj80 steering components and tierods, hub studs, aisin hubs, ifs 4-piston calipers, trunnion bearing eliminators, diff armor, Spring over perches. WMS = ~61"
Rear - centered cruiser/mini truck hybrid using the width of the IFS toyota rear axle. welded rear locker, 4.10 gears, fine spline pinion, multi pattern toyota pinion flange, differential guard, truss over the top, mount for trac-bar, e-brake cable setup. Comes with 1.5" wheels spacers. WMS = 58.5" + 3" (wheel spacers) = 61.5" WMS
37x12.5xr15 MTRs with Beadlocks - 5 total
Selling my 5 wheels and tires. tires have good tread, vehicle rarely driven. detailed pics to follow.
Wheels are welded beadlocks and hold air, 6x5.5 toyota/chevy pattern. 5th tire i use as mounted spare has a plug in the sidewall but holds air.
not willing to separate. The bead on these tires got damage chipped when tire shop removed them from a set of wheels, i haven't tried to mount them to a set of wheels other than using these beadlocks. i run these tires at 70 MPH no problem.
$1,500
Located in Gastonia/Charlotte
100 series custom Bumper with stinger bar. Built by UnderDawg January 2015. It will need sand blasted and repainted/powder coated.
MUD/ONSC price $600- I can bring it to Charlotte, NC, but need to know before September 6.
For sale: $250
5 80 series wheels with 31'' rollers (or without) 16'' 4.5 backspacing
40th edition (painted windows) decent shape, no scrapes but some oxidization. 4 ctr caps No lug nuts
For sale: $250
If you still have I'll take them.
Cool. Maybe @JohnVee or employee could cart back to Charlotte this weekend or I may be able to bring to Logan's.
I misread my calendar regarding this weekend but we'll be in Gboro 10-13th. Won't have room if they have tires mounted.
Any chance to meet up around 77 & 40 tomorrow afternoon? I'll be coming back from VA with an empty van.
cant do that one.... statesville is about 1.5hrs from here but thanks!
if the stars align and i head that way for anything ill shoot you a text
I have front seats available from my '70 FJ40. Both sides have been recovered but will need new foam. $250.00
No, don't want tires
Can meet Belmont is on the way to ellenboro
I can hold Quinton's 100 series bumper in charlotte for a while if anyone is interested
Holy roof reinforcement Batman. Must be the only sedan in existence with a fifth wheel hitch mounted on it's roof.
Outside the box, for sure.
Nope.
I was looking for that one^^^
For sale and not quite avail yet but soon....
5 37x12.5 r17 cooper stt
2 at 75-80% pretty good shape
2 at 35-40% have chunking esp on outer edges
1 at 20% for a spare
due to size difference i wouldnt recommend for AWD and also due to chunky tread would be best on a trail rig or at least not a DD
would plan to balance with beads of some sort
$400
can include 4 tundra rims for 300 extra
