Official ONSC member buying/selling thread
Anyone out there have a none rusted out radiator support bracket ( entire piece that hold radiator and headlights and other stuff ) for a fzj80 ?
Mine is in bad shape and seeing as it's getting a new to it tub ....
I should have some. Give me measurements out between the bolts. I have 40 driveshafts here.
The diff and tcase flanges are both 68.5x60mm
And the u joints are 32mm OD caps with the internal snap rings
What length do you need ?
I have a few here on the shelf.
I need 25" flange to flange at ride height. But I don't think that matches any factory length. My plan was to cut it up and get it retubed with 1/4 wall.
I have a couple here.
How much do you want for one? Actually looks like I could use one of those as they are. Unsure how long it would last but would be an easy option.
It's short by a couple inches.
Come get it and if you want throw me a 20 or not. Or we can do a mudship.
Anyone have a set of sliders? Even not for an 80 is fine if they're about the right length (about 63 1/2") I'm fine doing new mounts.
Third, I have 4plus sliders for a 60 series that the previous owner bedlined. I ordered and have new plates that weld onto the Fram from them as well. I am open to do some trading too. I will be at the relic run this year and can potentially make a run up to NC otherwise as I'm down in Athens, GA now. Thank you!
How long are these? And what would you want for them
I've got a set of sliders that I picked up at an event in Kentucky last year. Decided not to install them on my truck, so they are available. Manufactured by TKO fabrication in GA. They measure 68" long and would fit well on a 60 and probably a GX? Not sure what else. Fab skills needed to get them mounted up. Would like to get $600 for the pair.
Do you still have these?
Best contact is 919-869-4seven3seven. Everything is OBO. In my way
Bilstein shocks
-TG5125 12” shocks with boots. One boot is torn, they have maybe 3-4 rides on them. $150
-14” shocks. The dust seals need seated back in. Other than them being dirty they’re in good condition. $100
Sliders for a 84-89 4Runner and mini trucks, possibly other vehicles i can grab some measurements of the length if needed., 2x3 .120 boxed tube with 1.75 .120 tube. Dirty and a little rust and needs the slider mounts and tube cleaned off from my old exo cage. $150
ill have some more stuff posted up this weekend and some 80 stuff.
How long are the sliders? Curious if they would be long enough for an 80 series.
I have a set of slee step sliders for an 80 I’d part with. Slightly used once 😂
But seriously they are used. Some dents and scratches. USDS has very slight bow in outer tube portion only. See 2nd pic. More of a dent than a bow but I can get a straight edge on it. Have served their purpose very well for me and will for the next owner. Just may not be the ones if going on a purty truck.
$500
Can get better pics this weekend if needed
$500
View attachment 3570573View attachment 3570574
Well my truck isn't exactly purdy so I might be interested, bolt on would be easy too! Could you take some more pictures when you get a chance? I think I can see the dent in the second picture but curious to see it in all it's glory.
@Cornhusker the 8274 you referenced, if willing to split. How much work and how much would you need to Mud Ship to Relic Run? Project WTF is primed for a vintage winch.
I will get some pictures of it this week and test it to see that it's working. I'm guessing that it is an early one, as it has the Jeep label vice the Warn one. No mud ship would be needed. I'm already registered and planning on coming to the Relic Run.
