hey that's me ^^
Changed the truck status from "soccer mom" to "slightly less soccer mom". Here is the wheel and tire spec:
Wheels: Method NV 305 - 18x9 ET. +25. 5x150 bolt pattern
Tires: LT BFG KO2 - 285/65R18 - 37psi - laces out
Have you done front sensor lift? Has your LX always had that much front rake? Those vector 5s are sweet!
Wheel/tire size? Any rubbing?Y'all Give me MAD GOALS!!!! Here some quick picture after I got these wheels.
Wow, nice rig.. I want to keep my lx stock for the most part, but seeing yours makes me want to build it up.. I'm in the East bay, maybe I can see this in perso someday...Ok. So I picked the truck up at Dissent this morning. I finally had Ben install Slee sliders. I also finally moved to 17” wheels. I settled on Icon Vector 5s in satin black with 285/75/17 BFG KO2s. The truck rides so much better. I just picked it up and have not had a chance to get out and play, but here are some initial pics:
View attachment 2252351View attachment 2252353View attachment 2252354
Are those LC rockers or did you trim the stock steps?Ok. So I picked the truck up at Dissent this morning. I finally had Ben install Slee sliders. I also finally moved to 17” wheels. I settled on Icon Vector 5s in satin black with 285/75/17 BFG KO2s. The truck rides so much better. I just picked it up and have not had a chance to get out and play, but here are some initial pics:
Method 702 on 285/70/17. Yea they did rub. I had to trim. I posted the trim picture on the ahc mod lx570 page.Wheel/tire size? Any rubbing?
They are stock. The only cutting was on the ends. This slider is made specifically for the LX.
Unfortunetly can't say that I have.. I have a built 60/80/100 for offroad use, hence my decsion to keep the LX unmolested.. I would be down to take it threw some mild trails.. It is stock except for the 33's on 18's..Thanks. I’m pleased with how it is turning out. Now I am just ready to get out of the house and try the new wheels/tires out. Do you ever take the LX out on the trail?
It is now very close to my dream truck, except.....
We figured that there wouldn’t be any issues with rubbing since a lot of the usual culprit areas have already been removed for the bumpers and sliders. This is mostly true but while driving home on the interstate, occasionally when I would hit a dip that caused deep compression, I got some rubbing on the outer edge of both tires with a corner just a little inside the wheel well:
And so I am trying to figure out how to handle this. Should I trim this edge off? I am not sure that a heat gun will help as it is pretty thick right on this edge/corner. I thought about sanding it down, but I am not sure how far I need go. Surely not much. I guess I can sand and then drive, rinse, repeat.
Any suggestions?
Thanks.
No, no sensor lift. I think the rake is the same as when I got it.
Truck is looking great! What's the offset of those wheels? Can't tell from the angle of the pics but they look to be pretty aggressive and in the 20mm range?
I think you can heat gun that corner and push it in. If it doesn't work out, you'll be cutting it anyways. If you go low and slow with the heat gun, it'll soften up nicely and be relatively easy to reform.
