I don't know which one I want more: a supercharger or an auxiliary fuel tank.
That's pretty messed up.
Ima thinkin if you get item 1...you definitely need item 2...
Heck, I want item 2 even without item 1!
@Markuson ... still in SD?
Just to close this loop. The rear speed sensor wiring harness was the issues.
Which one is your go to?
We all understand Land Cruiser addiction...
...but can anyone else here relate to FLASHLIGHT addiction?
Only about 1/4th of my pile... Jut a bunch of black ones...![]()
Great reply. Thanks manIf I was forced to keep only ONE?
Over-all...if FORCED to choose one I could ever own?
No question. It would be the NiteCore SRT7 (two of them in the middle of the photo)...along with the NiteCore D4 charger (charges literally ANYTHING you can throw at it).
SRT7:
-Infinitely adjustable from 1 lumen to a legitimate 950...
-Also have legit strobe for AR/Intruder disorientation that is instant and full-brightness (many have strobe, but slow)
-Has separate red, blue and green LED mode for night, investigation & more
-Beacon mode
-18650 battery is quickly charged, great shelf-life, great non-use depletion rate
-Good flood, but also bright spot for distance
-Great power regulation
-Push-button on tail
-Small enough for belt or glove box...yet powerful enough to blow away most flashlights.
-Makes a fantastic tactical or defensive light on an AR or Benelli M4 shotgun with one-finger activation or pressure pad
-CLINCHER is the adjustment ring. -Lets you go SUPER dim so as not to disturb people in a hotel or tent...
Small, every Day Carry?
No question: NiteCore SRT3
-The SRT3 does EVERYTHING the P7 does, but 550 lumens, and a rechargeable rcr123 **OR...** comes with a tube to allow standard AA batteries in a pinch. -The ultimate survivor flashlight due to this option
Bad-Ass, Blow-you-away power:
-NiteCore TM26: 3500 Lumens of raw power
Tiny Marvel: Fenix LD01
-Barely bigger than the AAA it holds, yet surprising power with three levels of brightness.
PS.
Charger: No contest winner is the NiteCore D4. You plug it in to your 100 watt outlet in back of your cruiser, and you keep a couple 3400mAh 18650 lithium batteries, and a couple RCR123A batteries, and you always have fresh, super-powered batteries for the SRT7 and SRT3. Or...add a second D4, and you've got AA, or additional 18650s for the monster TM26 that takes four 18650s.
Great picture! Now I need to go round up all my handheld and weapon mounted torches and do a group shot. I've got somewhere close to 100 SureFire's!
Your squeaking is probably from the poly bushings and the cooler weather. Have you greased the UCA bushings?
