Off Road Lights
Palm Harbor, FL
Anyone know where I can find out my states laws on off road lights? I want to run some aux driving lights and I don't feel like getting harassed by the police.
I've searched fl DMV and cannot find the regulations that are required/prohibited.
Any help is most appreciated.
Don't know about FL, but in CA generally driving lights are 55W max & must be mounted at or below the headlights. If they are on a roof rack, they must be covered on the street.
thats my understanding for FL as well however wanting to find the specific regulations so I can be 100% sure.
i found this however I see nothing regarding driving lights.
It's like Ragu, it's in there;)
316.233 Spot lamps and auxiliary lamps
(1) SPOT LAMPS.--Any motor vehicle may be equipped with not to exceed two spot lamps and every lighted spot lamp shall be so aimed and used that no part of the high intensity portion of the beam will strike the windshield, or any windows, mirror, or occupant of another vehicle in use.
(2) FOG LAMPS.--Any motor vehicle may be equipped with not to exceed two fog lamps mounted on the front at a height not less than 12 inches nor more than 30 inches above the level surface upon which the vehicle stands and so aimed that when the vehicle is not loaded none of the high intensity portion of the light to the left of the center of the vehicle shall at a distance of 25 feet ahead project higher than a level of 4 inches below the level of the center of the lamp from which it comes. Lighted fog lamps meeting the above requirements may be used with lower headlamp beams as specified in s. 316.237(1)(b).
(3) AUXILIARY PASSING LAMPS.--Any motor vehicle may be equipped with not to exceed two auxiliary passing lamps mounted on the front at a height not less than 24 inches nor more than 42 inches above the level surface upon which the vehicle stands. The provisions of s. 316.237 shall apply to any combination of headlamps and auxiliary passing lamps.
(4) AUXILIARY DRIVING LAMPS.--Any motor vehicle may be equipped with not to exceed two auxiliary driving lamps mounted on the front at a height not less than 16 inches nor more than 42 inches above the level surface upon which the vehicle stands. The provisions of s. 316.237 shall apply to any combination of headlamps and auxiliary driving lamps.
(5) VIOLATIONS.--A violation of this section is a noncriminal traffic infraction, punishable as a nonmoving violation as provided in chapter 318.
so according to those rules, this would be considered illegal then? It says no more than 2. I'll have to dig around and see what Arizona law is. But what are the chances I get a ticket for having 10 lights on the front of my truck......zero in Phoenix anyway.
if all your lights are hooked up to the same switch than yes. If however 2 are driving and 2 are passing/fog than I think you would be fine.
Nice looking setup BTW
the two 7" are on one switch, and the two 4" are on another. Thanks for the compliment.
That's sexy.
If that's true, then I'm screwed :doh:
I've got an 1000 watts of lighting on my rack alone lol
No issues yet.
