- Thread starter
- #41
Maiden voyage last night. Stayed dry and nothing broken apart so that's a win!
Yeah, it's a good setup and there are some additions needed to really make it utilitarian.
I'll tell you one thing though, a 13BT with aired down tires (20psi) hauling an additional 1200lb trailer with tires also aired down equals getting nowhere fast...but once we hit the gravel it was slow going regardless (I hate potholes!)
I need to get more fuel to my injectors me thinks.
13BT's have a lot of power potential. 15psi, intercooler, fuel to match and you'll have power to spare I'm sure!
Another large improvement would be the wholesale auto valve body and torque converter, spendy but worth it in the long term. If memory serves me I think it locks up in 1st and 2nd gear.?
Got a couple 170AH deep cycle batteries that were used in some network backup power supply but were only ever on backup and not used. I don't know if they'll be any good, but I figured the fact they weigh 100lbs each meant they had something inside them. And no, I apparently do not care how much weight I'm adding
A few more wiring additions and some tidying of a few wires (temporary hookups for testing purposes) and I should be able to have a fan running through the night during warmer trips.
I really don't want any roof penetrations so I've opted to route the solar panel wiring somewhat uniquely, also hoping to avoid branch/tree rubbing the wires by avoiding the side edge as well.
Is that a WorkSafe approved 1x4 holding the 100 lb door over your head, on that fairly slippery aluminum?
Not sure how to drive home with two broken legs, concussion. You worry me, my friend.
Kind of built a better mousetrap!
Did some clearance R&D in the camp's back40 today after questions regarding access to a certain place.
Turns out I may need to swap the trailer pintle onto the bottom side of the tongue as it got kind buried. Rear bumper was rubbing but spare tire still had a few inches before touching the alum box.
What happened when you drove down the other side?![]()
Then did some more wiring, or rather electrical systems building.
Gotta love when your buddy scraps an ambulance and says you can strip it of whatever you want! Got some nice electronics and lights and wiring.
Cool.
You could maybe glue a gasket to the side of the trailer for those shelves to seal against when they were folded up?
Might cut down on the cleaning...but might also be more trouble than it's worth.
