OEM wiper blade is NWB
Odessa/Midland TX
Just wanted to share this.
NWB: Nippon Wiper Blade
These wiper blades are the OEM for Toyota. It will not stick to glass even with a very light rain. Wipes smoothly and streak free.
If you find any OEM wiper blade still in the truck (mosly likely the rear), you will find NWB embossed on the blade frame.
More here: NWB COMPANY
Would like to try but expensive, driver side - $29.76, passenger side - $24.24 and rear $15.44 @ carparts dot com
I have goodyear wipers, I guess I need to replace those with NWB wipers and there after I can do only the rubber inserts. Thanks for the info
Might have to give this a shot. I have mid level Bosch wipers and they chatter like crazy. Gonna have to polish the glass to ensure there is no issues. But think with Alita I am going to have to invest in higher end wipers.
I switched back to OEM recently. They work flawlessly. No chatter, no smearing!
Don't know that it is consistent across all years so easiest way is to drop your VIN into Partsouq and get everything needed from there. Likely will be on my short list this fall.
The OEM are like $21 when on sale or $25 normally at Bell Lexus parts with free shipping. These are same Denso first fit sold on Amazon and Rock auto. I can confirm the Denso is exact same plastic as OEM only difference is rubber inserts say NWB on Denso vs OEM dealer version. I switched all my cars to Denso/OEM. Also Honda, Chrysler, GM, and other a Korean cars use same blades.
