OEM Painted Rotor
Did a routine plugs, wires, cap & rotor PM. Seems toyota had a cap & rotor, one box store had plugs, another box store head wires.
The rotor that I got directly from Toyota had a dab of some kind of paint on the tip of the rotor where it should be sending the spark to the cap & wires. I tested for connectivity, and the blob of paint was blocking current flowing from down the rotor to the top
Why does toyota put paint on the tip of the rotor ? Has anybody else seen this on a part directly from the dealership ? It seems to do nothing except I interfere with the function of the rotor.
My guess is that your distributor is the small-cap-type for an F engine. Later Nippondenso distributor rotors don't have this. It cleans-up/removes, if you ever feel inspired to clean your cap and rotor.
I've never seen it but my guess is it might have been put there to prevent corrosion while sitting on the shelf. Don't know if it was to be cleaned off before install or was designed to be chipped off by the contact when the rotor spun inside the cap.
The black rotor is new out of the box from the dealership. It came with a thin black line of paint on the tip. Probes on the end and the center, do not conduct.
It's not paint. The substance is a plasma coating intended to suppress radio interference noise on conventional distributor ignition systems.
The following is a link to the Toyota patent.
