OEM, Iridium, Platinum??
Wayne
Bought by His blood, kept by His power
Middleburg, Florida
Since we're supposed to change our plugs every 30K . Do any of you run Iridium or Platinum plugs in your 1FZFE?
Depends on what you want to pay, how lazy you are? I prefer Denso (OE). Stock is Copper, ~$1.50, good for ~30K mi, platinum ~$2.50, good for ~60K mi, iridium ~$5.00, good for ~100K+ mi.
Plug life expectancy depends on how well the vehicle is running and if there are any oil leaks (for instance valve stem leaks). A plug that can get fouled out at 10k miles from running rich or oil leaks will foul out at 10k miles regardless of plug type.
Multi-point plugs are a pure gimmick. Don't let anyone tell you otherwise (however, a double platinum tipped plug is different - that isn't a "gimmick" thing, especially for vehicles that have a waste spark setup. That isn't multi-point, that type of plug has platinum on both sides of the spark, but only 1 electrode).
OE was probably Nickel (which is what NGK V Powers are) or Platinum, which will be stated on the underside of the hood.
I just let Dan toss the factory reccomend in my box o' parts whenever I do the light tuneup. IIRC it's the Denso.
I used iridium for about 75K and was happy the entire time. Replaced them when I did the valve cover gasket about three weeks ago and they looked pretty good, but it definitely ran smoother with the new ones. I will probably replace these at 50K.
I used the Iridium, and I'm really happy with them. I only put 5K miles a year on the truck. It's almost a lifetime plug at that point.
I have used the Bosch Platinum 4 ever since I purchased my truck over 8 years ago. I have just changed them with almost 125,000 kms on them. All looked very good. Will change the ones I just installed in another 125,000 kms assuming everything else remains the same.
In th majority of vehicles... It makes no difference what kinda plugs you use...
Ive got away with bosch, and autolites in my 4runners....
Did they run as smooth as denso?
No!
But they also didnt adversely affect my mpg, or overall running.
In fact... I once swapped an almost new set of bosch plugs, for brand new factory denso... The denso's def made it idle, and accelerate smoother, but mpg's and overall running was the same.
Of course, with some engines (mazda rotary comes to mind) thats a different story, but the vast majority dont seem to care either way.
Seemed to get slightly smoother running/acceleration with Denso Iridium's in my 1FZFE compared to OEM standard plugs, replaced the worn set of Iridiums after 100,000+ miles with a new set which now have ~45,000 miles on them and the engine is running fine. Main advantage IME and as Tools mentioned would be not having to change them as often as standard plugs.
Another way to think about this is that regardless of the plug life expectancy I would say that removing the plugs on a regular basis is a good idea. Our engines are pretty old already and it never hurts to peak inside the cylinder and check the plug condition - which will tell you a lot how the engine is doing. Heck, while you are there do a quick compression check and have that peace of mind as well.
All that said - I change my plugs every 30k miles and use the OEM Denso
I use platinum plugs and change them every third oil change out of habit. Holdover from my Jeep days I guess. As Toyofan said, it's a good diagnostic tool, and as long as they come out, might as well toss new ones in. It's not that $$ in the big scheme of things.
