I am putting a new oem toyota manifold gasket on for the 2f. I was wondering if i should put this on dry since it is metal or should i use any other sealant? I would say dry but it doesn't hurt to be curious. thanks
looks like ill go with the copper seal spray. where is this available? pref. without ordering. thanks
Is the loctite proven to be better or are they basically the same product??Use LOCTITE 37583 9oz Aerosol Copper Gasket Adhesive when you need a fast drying metallic copper sealant that helps dissipate heat prevents gasket burnout and improves heat transfer. Seals instantly. Fills hot spots and surface imperfections
