Nice!
Looks like those springs don't have much curvature to them. Will there be enough room for articulation?
are you saying that the axle won't move with respect to the frame when you go over bumps and such? If that were true, there would be no need for springs at all.
If it wasn't clear I was wondering about the spacing between the top of the axle and the frame.
well, if it was spring-over before and you now run it as spring-under, that will decrease dramatically the free space for axle vertical motion ( between highest point and frame). Looks like the spring mounts are just about even with the top of the axle now, so you'd want fairly long mounts/shackles, I would think. Like in that spring-under axle pic just above, there is indeed a good deal of space between the top of the axle and the frame, but that is likely at least partly because of the rather long spring mounts/shackles, looks like. If you don't have that on your new trailer is there a chance of contact perhaps? And will shocks if any have to be changed?
Fantastic!
Can the springs be de-arched (flattened) to drop the height midway between spring-under/over and fix the stink-bug on the Oddball80 issue?
Nolen, sorry for getting off topic here, but why do I like that 80 so much. I don't care for the newer Cruisers and know nothing about them, is there something different with yours?
Cliff NotesWas that an import?
