Sam, Christo and I spent a boat load of time trying to brainstorm a way to mount the upper Fox shock mount above the stock shock perch to no avail. I originally thought ("assumed") the 80 series and 100 series upper shock mounts were very close in design...but they're not.
I actually thought I had it figured out once today...and may actually have done just that...but the only way to really find out if it would work was for Sam (Sam was about 50/50 on this approach) to actually do the fab work. I could see his concern for the potential limitation/issue...so we decided to move the shock mounts to the rear of the axle via custom brackets top and bottom per his ultimate recommendation. This accomplishes many things including moving the lower shock mount behind the axle housing and about 4" higher up for maximum protection; cutting off the lower stock shock mount thereby eliminating a rock snag point; making the complete shock system easily accessed; and more than likely longer travel with this mount system.
Sam utilizes a similar mounting system on the H2's he mods for Rod Hall and others....and it looks quicksilver alright.
Supposed to be done sometime next week.
Pics when available
P.S. It really SUCKS being the first one sometimes!!!!!!!!!!!!!!!!!!!
