OBA question
Seattle
so it seems with all the parts needed to complete a sucessful running OBA set up wouldnt it be cheaper to simply buy a regular house comressor (one with a smaller tank) and strip the parts off you need to run your OBA? couldnt you get the tank, pop off valve, pressure switch ect... Any thoughts?
A very small air tank will work on a vehicle, say less than 3 gallons.
The pop valve will work and that's what I use for my OBA.
Pressure switch - I know that folks use these clunky things that are adjustable but there are WAY more choices of press switches that are very small in size. I use the one from Quickair 80/105 and there are many others with various press ranges. 80 - when air comp turns on 105 - when air comp shuts off.
This is also the press range that the ARB lockers can handle w/o regulating the air down.
Here's what I have: http://www.flickr.com/photos/alia176/566838208/in/set-72157600396020689/
Cheers.
ps: two sliders + 2.5 gallon air tank = 6.5 gallon air capacity.
This is a rolling compressor tank setup (8 gallons) put up in the spare location. Filling it with an extreme-air with a VIAR pressure switch.
Excellent job Dan
Well, how would you run the compressor itself? Are you talking about using the actual compressor, or just the switch, regulator, and tank? If just the parts, you get what you pay for, if you buy a cheap compressor you're buying cheap parts. If you just need the parts, maybe find a non-running compressor in Craigslist and cannibalize it for the tank and controls. If you're thinking of using the actual compressor, without a clutch it's gonna be tough to shut it off. I'm not sure if that's where you were going with the question or not.
-Spike
If you have 33s get a CO2 tank and walk away...easier, portable, and works great. OBA systems (unless you get a York) need a lot of time to fill tires, etc. I can run tools and even air up my 37s, but I have to wait for the volume to recycle often...not too fun.
sorry. i plan to run a york, i have the bracket already. the york is cheap and easy to gt ahold of the other bits are where the cost seems to go up. i already have a small 3 gal tank however i would consider going a a bit bigger if i got a compressor. after looking on craigslist i see a ton of compressors for cheap and i though why buy everything seperate if i coul just buy the compressor and swap it over. is it worth it?
mike
if you add the two sliders toyour existing 3 gallon, you'll have 5 total. Having a york, really makes extra res capacity not necessary since the CFM is very respectful already. Did you figure out how to run the york or did the 3 groove pulley been sourced already from Slee?
I see what your saying. If you do your shopping, you can find all of the parts cheaper and get what you want. www.airbagit.com has some stuff along with a bunch of other places. Do the E-bay thing and search for what part your looking for. Thats a good way to find this stuff cheap.:beer:
One thing I will change on mine is I have the pressure switch that cuts out at 105.....I'd like to get up to around 140 to run the air tools longer.
If you're at 140 psi, then are u regulating the air down to a more reasonable pressure for air tools? Have you tried to expand your storage capacity?
