O2 Sensor Question
Northwest Arkansas
Hi folks
I've just gotten a '92 model that needs to have the upper end of the exhaust system replaced. The catalytic converters are shot and one of the O2 sensors have fallen out of its mounting bung.
I took it to the local muffler shop to get a quote on having this done. They can custom build the components but expressed concern that the O2 sensor mounting bung that they would weld into the head pipe may not fit the older O2 sensor that this truck uses.
The muffler guy claims that there are some older cars in which the O2 sensor does not control the fuel/air mixture. He further states that you can eliminate the O2 sensor on these cars without affecting the performance. He asked me to do some research to find out if this may be the case here.
This is contrary to what I understand, but told him I would check into it. Has anyone heard of this?
I'm pretty sure the O2 sensors are an important part of the feedback loop on an EFI engine. While it might be possible to run "open loop" using only the VAFM (air flow meter on top of the filter canister), the ECU will have no idea if the mixture is truly correct.
^ X2
