O2 Sensor - Code P0135 - Replace all?
Just ordered two of these myself. I'd be happy with getting any mpg gain at all, but 2mpg is nuts. Fingers crossed that this will put me above the 15mpg mark...
My mileage was getting really bad over the last 10k, which I now understand is a common symptom of aging O2 sensors. It's been only a few weeks, but I am getting about 12/16 instead of 10/14.
pegasis0066 said:
How do you get those da#m plugs to come apart?
PB Blaster. Torque, untorque, repeat. Make sure to use a lot of that included anti-sieze compount when putting the new ones on.
If you still can't get them off, then you might want carefully try when that area is still hot as the metal expands a bit. I had to do this one one side.
- Sent from a very small supercomputer.
Push the release clip in.
Pushing till fingers are numb. Not sure I can push any harder. I think there's only one release clip on one side but not sure. Although clearly I am missing this specific spot to push.
Look at the new part. You'll see exactly what the connections are.
Yeah, looked at male plug on new sensor and see the little clip on one side, but for the life of me can't release it. It shouldn't be this hard, but always is for me!
At least you got it. Glad I did mine with the DT header install. G/L hope your CEL is a thing of the past. Maybe you'll pickup a mileage boost while you're at it. Remember to reset the ECU and give it time to re-learn idle before you drive it.
Bingo.
The re-learn idle bit is a much overlooked and very important step. My truck is much smoother now across the board after letting it idle for 15 minutes after reconnecting the battery. Hopefully it will slightly increase my dismal 10 MPG.
I need to do my rears but they are super rusted. I have sprayed them a couple times this weekend so maybe in a week or two they will be ready.
I noted they each have two bolts and don't screw in like the fronts, and to make things more interesting to remove, they bolt in from the top.
Are tricks to get these out, other than elbow grease and patience?
Can't help you there. I've only done the fronts so far, besides here in SoCal things don't generally rust, so mine are rust free. You may want to buy replacement nuts for the rears before you try to remove them.
Ok so I haven't ordered rear sensor yet, but had time today to see what I was in store for. After loosening the bank 1 sensor 2 bolts, I decided to run down to the hardware store to get some stainless steel nuts so that when I do have to replace them (which will be soon) removal will be a snap.
I purchase metric 8 x 1.25 nuts, after checking the OEM one the hardware store's nut/bolt gauges. So I run home, quickly replace the previously loosened bank 1 sensor 2 nuts. Flip over to the other side's rear, and discover original nuts are in pretty poor shape, and I can't even get a wrench tightly on them. So I think why not try to crush it in place by putting the new stainless nut down on top of it. I quickly discover the bolt stems on this side are smaller and my 8 x 1.5 nuts are too big - how can this be?
Has anyone experienced this - the bolt stems on the rear sensors vary in size, one side vs the other?
I am gonna guess it is rust related. Check with a Toy dealer though and see if the two nuts are the same part number.
I'll bet ya a MUD sticker that it's rust related.. Just call Onur (Beno) at American Toyota, ask for the nut part numbers.
