What are steps involved for a non-mechanic type?
You could either try to find a local shop to complete the entire job for you or you could purchase a complete Orion and do the install yourself.
Georg
My Orion nose cone seal is leaking like a sive. It is leaking from where the cone meets the case. Is there a write up that anybody knows of which outlines taking the cone off to replace the seal? On the outside it looks like the 7 or 8 bolts holding it on circumferentially, the shifting linkage, and the front drive shaft to take it off,and the nut that fits at the end of the nosecone infront of the drive shaft. Is there something else that I would need to be prepared to remove? will the internals of the case come falling out when I remove the nose cone? is there specific internal nuts that requires a specific torque, or other nonreuseable oil rings/sleves that I would need to replace as well?does anyone know the best place to get a new seal/gasket.
(I noticed there was an Orion link in the tech section but the link wasnt working for me saying the page expired)
Thanks for any enlightenment
That was an awesome response!!! Thank you Georg for taking the time to write that all out. I will look again to make surety at is where my problem is and if so I'll contact you for the parts
Thanks again.![]()
