Nuts and Bolts
If you mean this one:
it's a Ø4-mm x 10-mm long sheet metal screw. There is no specified installation torque; turn the screwdriver until it doesn't turn anymore.
You won't find an exact replacement at the local hardware store; the thread form is unique to the JIS automotive standard. And the head is smaller than you'd find in a similar size sheet metal screw; also unique to the JIS automotive standard.
You may be able to find one here; I haven't looked.
Thank you, I should have been more specific. I was thinking about the upper dash pad.
This one?
as the part number indicates it's M5 x 0.8 x 14-mm long
All for M10 threads. @Coolerman 's spreadsheet suggests M10x1.25x30mm. I think Toyota used two studs to aid in locating the box during assembly. I recommend checking the threads in the bracket to confirm the pitch.
94110-51000 nut $1.44 list
94512-01000 washer $1.47
90116-10101 stud NLA
91112-71032 hex head screw NLA
Two studs on the inboard side, two screws on the outboard side.
Thanks!
Add to the supplier list....
METRIC SPECIALTIES INC
Great supplier for all your JIS sizes. Awesome prices. Shoot them a list of what you need, and they will get back to you in a day with what can be immediately filled. They are in SoCal in Santa Clarita and have a WILL CALL window to pick your order up if your local. Very cool folks running the shop. They had eveything I needed including some of the engine bolts that had odd shoulder sizes.
Need the specs on the bolts that attach the clutch plate to the flywheel. I didnt see those listed on the spreadsheet.
The clutch doesn't attach to the flywheel. The pressure plate does.
It depends on 3 speed vs 4 speed, and possibly, year of manufacture. Shouldn't you provide more information in your request for information?
Sure. The Pressure plate. 4 spd. unknown year.
For the 4 speed pressure plate and flywheel, part no. 90119-08134
Transmission Clutch Pressure Plate Bolt - Toyota (90119-08134) $1.61 list price​
