Well I have a few more updates on Shane's harness.
First off, thanks to Merbesfield, Shane will have a more accurate repair of his harness.
Shane was missing most of the drivers side of his harness and I was going to have to guess at some measurements. Merbesfield told me he had a harness that was in good condition and offered to ship it too me. He was not correct, this harness is about the most pristine harness I have ever seen! It's got a few repairs done to it but everything is there and the repairs were done well. I was able to quickly add the missing sections to Shane's harness today.
Shane's main harness has been put back mostly stock but I added a few things to it for future changes.
One, I added a wire that will allow him to relocate the coil/igniter to the inner fender later if he decides to go to an FJ60 system. All he has to do is unplug the stock coil wire and plug it into the added wire to extend the switched hot to the inner fender.
Two:Changed the interior light power feed so that all he has to do is activate the switch on the light instead of having to also turn on the headlight switch to position #1.
Three: Added a fuel cut-off solenoid wire for when he upgrades to the later carb. This is fed from the regulator sense wire.
Four: Moved the reverse light wires from a column shift to a floor shift.
In addition to repairing the main harness I also built him a completely new harness for the wipers and for the bib. The only thing I have left to do is build the new rear harness and tape the main harness.
See pics...
