Yes.Is Toyota out of them?
Thank you. I will check on his site. It’s down through tomorrow so I thought I would post a wanted ad just incase.Chances are Roger still has one Gabe.
Yes.
I knew that is why you were asking so I didn’t want to comment. lol.wonder if it's out for good or just no stock?
I have one on the shelf, just not sure I want to sell it if they are now unavailable.
I’ve been inside Paul’s shop, so I can sayi know what else Paul has a few CASES of on his TEq shelfs![]()
Does anyone know if the RHD version only differs by the location of the reservoir return nipple?
I guess I'm asking if it's possible the pump body will bolt up the same as LHD and just swap reservoir? I've never seen a RHD one to compare.
I’m no longer with Toyota so I’m not sure. Out of the loop now. Do you have the pulley too? If so shoot me a pm if you decide to sell it. I’m putting a 2f dressed like a f engine in my fj45 that I added factory power steering gearbox to.
I already had the engine, trans, and t case built.If that is what you are doing then you should do the 3FE w, it bolts right up to 2F like on the world-market location 2/3F. Then you can keep the driver’s side lower location Alt and early round air cleaner.
Do you have a new 3fe ps pump then?3FE power steering pump. Not the whole engine.
Ive done this a few times
Oh I will find it. That is part of the fun. I enjoy tracking down all of the pieces for my projects. The problem is what will it cost me and is it worth it!when you find your UNICORN Indy . ill mail you a set of these for your St. Patricks day Gift ...
( Chrome Foil Heavy Duty Type ) Power Steering Pump Reservoir Decal Toyota Emblem Plate Label JDM / USa spec. FJ40 , FJ45, FJ55 BJ40, BJ42 , FJ60, HJ60 , HJ62 , HJ47 , HJ45 , 2F , 3FE, 1HZ 3B , 12HT - VintageTEqParts.com
( Chrome Foil Heavy Duty Type ) 1st Generation Power Steering Pump Reservoir Decal Toyota Emblem Plate Label JDM /...vintageteqparts.com
( Updated Chrome Foil Heavy Duty Type ) Power Steering Pump Reservoir CAP Decal Toyota Emblem Plate Label JDM / USa spec. FJ40 , FJ45, FJ55 BJ40, BJ42 , FJ60, HJ60 , HJ62 , HJ47 , HJ45 , 2F , 3FE, 1HZ 3B , 12HT - VintageTEqParts.com
( Updated Chrome Foil Heavy Duty Type ) 1st Generation Power Steering Pump Reservoir CAP Decal Toyota Emblem Plate Label...vintageteqparts.com
