For Sale North Bay CA, 2014 Toyota Land Cruiser 200 *SOLD*
I am selling my pristine 2014 LC200 due to changing needs. I have owned this for about 10 months, and bought it in DFW, Texas where it was a One-owner vehicle with a full service record at One DFW Toyota dealer. I got it with 54,800 miles and have absolutely babied it. It is currently at 65,xxx miles and residing in Northern California (just north of Marin County). Right after I bought it, the truck got a full detail with clay bar and 3 stage clean/wax process, to include full weather seal conditioner. There are absolutely no dents in the body, and only 3-4 very small paint chips that can be seen from 2-3 feet only. There is not a spot of rust on the vehicle, absolutely no leaks of any sort, and even the engine bay is spotless.
The following maintenance and modifications have been performed. Please note that all fluid compatibility and weights have been followed per Toyota recommendations, to say I am OCD about these things is an understatement.
Full baseline completed in January 2019:
Amsoil Engine Oil
Amsoil Transmission Fluid Flush
Redline Max-ATF power steering flush
Amsoil Transfer Case Lubricant
Amsoil Gear Lube in front and rear differentials
Amsoil Brake Fluid Flush
Toyota OEM Aluminum oil filter housing with Mobil 1 Oil filter and Fumoto oil pan drain valve
Brake job completed February 2019:
PFC 2-Piece front brake rotors
New EBC black rear brake discs
EBC Yellow Stuff front pads
EBC Green Stuff rear pads
EBC parking brake shoes
Speed Bleeders on all 4 corners
Amsoil brake fluid full flush
Suspension (Professionally Installed)
Radflo 2.5" IFP Coil-overs (600# springs in front), OME 2720 Springs in rear
SPC Front UCA with 5,000 mile grease intervals
*Drives bolt straight down the road*
Other:
Bud Built Straight DOM Rock Sliders (black powder coat)
9011 HIR bulbs installed in High Beams
Yellow LED fog light bulbs
LED corner and signal bulbs
DiodeDynamics LED flasher relay installed in stock location (no short cuts with zip ties here)
BFG K02 285/65R18 tires on all 5 factory wheels with 5,000 mile rotation (currently at 9,000 miles and basically new tread)
35% front window tint
AFE Power Dry engine air filter
Carbon Cabin air filter
Engine/Radiator Coolant flush with Amsoil Long Life compatible coolant
ClearBra on Hood and leading edge of front 1/4's, all 4 door edges, as well as side view mirrors
Brand new Toyota DVD IR Remote
I think I am missing some things, but I've basically covered it all. Please reach out to me at XXX-XXX-XXXX if you've got any questions. I have absolutely babied this thing, and completed maintenance and care to a degree that could only be described as meticulous. Everything on this truck still works as factory, and even the interior is super clean. The Cool box works as new. Disclaimer*** The Air recirculation door was broken by some ham fisted tech at some point in its life. It was able to repair it with a careful application of polymer epoxy and reconstruction of the hinge. It works 100% now, and shows no signs of weakness with a 100% function check and no air leaks/noises. FWIW, it is now basically as good as new, but it is the only thing that has even been wrong with this vehicle.
Also, another engine oil change, tire rotation, and UCA greasing was just serviced under 1,000 miles ago with Amsoil Signature oil and Mobil 1 filter. Sale will also include 1 additional set of new-in-box PFC 2-Piece front brake rotors.
I am asking $46,000
Hey guys, plugs were also replaced with NGK double iridium factory spec spark plugs and torqued to Toyota spec at 56,000 miles. I knew I forgot something.
That's a great truck! With so much care and attention, why are you parting ways?
It basically sits for the most part, and I could use the utility of a small pickup like a Tacoma a little more. I adore this thing, and hope I’m making the right decision, but figured I’d give enthusiasts first crack.
Hey guys, I’ve got some inquires about photos videos etc. Best way to contact me is by the cell # provided and we can text photos or FaceTime for real time preview. Thanks
Thought I'd update the post with some pertinent info that has come up. KDSS valve is in perfect condition. When the lift was completed, I was concerned about popping the screws loose, as I've heard about stripped hex holes, etc. Well, it opened and closed just fine, and cruiser lean was never an issue. The bare iron surface gets a regular coating of black moly grease on my service intervals.
Also, it gets a regular application of tri-flow to door hinges, hood hinges, latches, and shock shafts to keep seals in order and squeaks in check.
