Yeah I’m going to take a look at my situation....... I was sitting for a while but don’t think it should have gotten that high.230 and you better be very worried. 250 is engine death.
Personally anything over 220 and I'm turning the a/c off.
My old cooling system ran 195-205: highest recorded ambient temps about 112-115F. New cooling system has ranged from 186~193 mostly stays between 186~190 in 95F ambient temps.
I think 225F is high on a 100 series and indicates potential for a cooling issue; its warning you.
If you were sitting and it climbed that high check your fan clutch. Also check that the coolant is full
to the top of the neck of the radiator, and that the fins on the front of the radiator (and also condensor) arent clogged debris and impeding air flow(mine had a good amount of mud grass and pine needles sucked up along the lower corners and edges)
Another thing that adds heat to the cooling system is the internal trans cooler. Check your transmission fluid: correct level and good ruby red color.
After all that checks out it may be time for a new rad.
