Nomad Convoy Wheels
Man, if those 504’s were avail, I’d get them right now, but I need wheels for mid May, and they can’t offer any delivery guarantee’s
For sure but Nomad is marketing directly to the 100 series crowd on their website but only sells one or two wheels in their entire line up in the offset range most of us are looking for.
I also wish they offered more. Based on what they have said to me they will have 3 wheels in a positive offset. The 501, and 504 we know for sure, and based on my message with them the 505 will come along too.
I have decided that I will be ordering the 504's in +35 when they become available
Man, I am a bit sad, as I need a wheel done and mounted by mid May, and they can only offer potential early May….so stuck with the 501 in a +25. Should be still really cool, especially with 2” body lift and 37” Yoko’s
I went to the Ovelanding Expo and stopped by their booth here is a up close pic of the 504
Do your tires rub? Thinking of doing a similair setup.
I needed to flatten the pinch weld and remold the fender liner but other than that no rubbing
I put the 504s on today. Went with the +35. Some pics with the standard cap (need to get the taller caps for the front) and one pic with the retro in case it's helpful to anyone. Still need to clean them up. Tires are Falken Wildpeaks in 285/70R17.
*By the way, what's everyone doing for a spare? Didn't want to pay for a 5th wheel and tire. Can I get away with just putting a similar diameter tire on the existing spare?
Cool, but glad I skipped on this model, looks pretty much like a steel take off
Thanks for posting. I hounded NOMAD for a few months waiting patiently for these wheels. First they were going to be available in April, then May, then june came along and they said it would be August. Turns out it was September.
Not their fault as I believe the situation with tariffs and the ports caused the delay. I at least get to look at your rig instead.
I got tired of waiting and went with Fifteen52's instead. I bought a 5th wheel but thats because I plan on running a rear tire swing out. Most folks around here will tell you that running a tire of a different size is a huge no no, and I agree to a point. If the tire is drastically a different size your diff will not like it. But if it's close enough and the difference is minimal I dont see the issue.
This was discussed to an extent in this thread
Here are my wheels in the machined finish. I decided to not do the panda look at the last minute.
Is -10 too much? I am planning on running 35"s once my current tires are done.
Also, running F&R aftermarket bumpers with sliders.
There is a deal near me for 5 new 501SB convoys for $750 in -10. Might buy just to resell....
Kinda hard to say anything when you don't say how WIDE the tire your thinking about getting is.
Stock wheel offset and width.
Those offset and width.
Use imagination to compare.
Stock is +60 (2.3in)
The new wheel would put it 70mm (2.76in) further out than the stockers.
Yeah, good point. I was thinking
Tire WidthWheel Width
10.5″-11.5"8.5"
Had this wheel/tire combo on my 2nd gen Sequoia but ended up putting them on my 04. (Front wheel caps aren’t on yet.)
Still looking for the right wheel/tire combo for the 100-series, but running this while the Sequoia has its winter tires on.
Could you post some pics of them on your sequoia? A friend is considering them for his 🌲. +25 and what size tire?
