No Start
McDonough, Georgia
Here is the problem. New battery with ablolutely no turnover or ignition when the key is turned. Anyone with any ideas what to look at first? I am leaning towards a voltage regulator or distributor. Can a bad alternator do this?:confused:
Make sure your positive and ground post connections are tight.
If you're getting nothing, then it's an electrical issue, or a starter issue, or maybe you received a dead battery?? You're gonna have to give us more information...why was the battery replaced? What kind of battery? What is condition of the alternator, or for that matter what is the year of your truck.
The only thing we know for sure is that you bought a battery for a Land Cruiser. Not much to go on, if you know what I mean.
If you have no lights, no buzzer when you put the key in the ignition and no horn, then no juice is going from the battery to the vehicles electrical system, If this is the case, check the positive connection to be sure you hooked everything up correctly. On my Cruiser there are three cables that connect to the positive terminal of the battery; the big lead that goes to the starter, a smaller lead that has two wires on it that are fusible links and feed power to everything electrical in the truck, and I have another wire that carries power to my inverter. So, make sure you got everything hooked back up on the positive side.
Thanks for the information. If I could give more detail I would, however I am currently deployed with the airforce and it is my wife who gave me the info. She had a friend put in the new battery and from the results at least the lights came on and I can only assume that other electrical indication did as well. Can't trouble shoot until I get home next month. The good news is that she has her own 97 fj80, so she will be just fine. Can't wait to get home for some good mountain driving in north georgia and north carolina. This desert is pretty dull!
