Not trying to pick on you at all, just trying to understand, because I recently replaced my negative battery post, and I did not find the need to modify anything whatsoever to make it fit. The two negative wires fit right into the clamp area, and I tightened down the nut. What did you have to modify?
I can see where you might have to modify something for the positive post because everything sits on that one plate with a hole in it.
Also curious why they include a cover for the negative battery terminal.. I often see a cover on the negative, but not the positive terminal. What's the point? You have exposed ground all over the place anyway. The positive battery terminal is the one that needs to be isolated from everything. Which by the way, the original OEM positive terminal cover doesn't even fit very well on the OEM clamp.
