No speedometer after starter,phh
97 fzj80.I put new starter contacts in and phh bypass.I also replaced themostat and heater valve ,fhh hoses,radiator hoses.I now have no speedo or odometer and trip odometer.
I figured maybe i knocked a wire or something.I cant find anything obvious.I found ground wire on manifold it looks good.Ialso pulled vss. Plastic sprocket looks good along with shaft.I guess i need to figure out test for vss but it seems way to coincidental that it would go out now.I am also getting check engine code po500.
The speedo sensor wiring goes through the 3 or 4 connectors right between the PHH and starter. My guess is something happened with those.
Best case - loose connector
Worst case - loose contact in the connector
Those connectors are a pain to work on.
Same thing
I had the same thing after I bypassed the stupid PHH with 4' of Silicone hose and good constant torque connectors. Looks like the plastic of the connectors after 19 years has gotten to the point that any brushing of it means cracks, or shatter. I talked to CDan the other day, he says the wiring goes from the side of the xfer case up on top of the tranny/xfer case. So I am looking at replacing the wiring as it is broke as hell. I also found that while in that area replacing the PHH I broke a coolant temp sensor connector as well, need to replace that too :(
Sean
Thanks for replys.I was afraid of it having to.with wires near starter.I guess starter has to come back out.I can't see trying to work on wires with it in there.
