Resurrecting this thread with same/similar issue. Knocked the center dome light while installing some extra storage I use offroading in place of my 2nd row seats. Someday I'll just leave that in and ditch the 2nd row! Regardless, the lid hit the center dome light pretty good when I opened it while putting the bolts in. Later on noticed the alarm for the truck wasn't working. Looked at fuse panel at steering wheel - nothing blown. Fuse box in engine bay and lo and behold the dome fuse was fried. Replaced it and tried manually turning on the center dome light. Fuse blew again. Replaced it again and have been good so far. Didn't try the center dome light again as I was down to only one more 10amp fuse!
@Gunky - if you're still around, how far up was that 6 pin cable behind the DS kick panel? I know one of the two rear door sensors is going bad because I'll occasionally get a dome light flicker taking turns, etc. Yes, the doors are closed and locked. Need to replace one or both of those at some point if they are still available!
Based on a few threads on this dome fuse, could be this 6 pin connector, could be that I knocked something loose behind that center dome light and will need to inspect it too I think. Perhaps some aging wiring at the dome light. I'm not drawing much current as I put some of George's LED bulbs in all the dome lights centuries ago...like when he first started making them! Damn I'm getting old.
