No power at AC controls!
Yeah.... I was testing my AC amplifier following the guidelines and suddenly no power at all to the AC controls. I pulled the board out and went through the whole test of everything and the control assembly test fine. My problem is that the AC compressor won't kick on. I've changed everything including the AC Amplifier except the control assembly, blower resistor, and the thermistor as they all have tested fine. Now I'm stumped. I've tested the following
AC fuse
Blower resistor
AC amplifier (in complete as no power to controls
Relay (one above the evaporator. Is there another one?)
Pressure switch
Coolant temp cut off switch
I need help. No power to AC controls at all. Radio is aftermarket and has power.
You ask if there is more then one relay, there are three relays, (at least on my 94) one for the heater, in the relay block next to your left foot, and two for the AC, both inside the pass. compartment (B6 blower speed control relay) and (A14 AC cut relay) both are next to the evap core. A14 AC cut out relay is feed from A10, the AC amplifier, and controls the AC magnetic clutch, and water temp switch, B6 the blower speed relay is feed from a 30 amp heater fuse in the fuse panel next to your left knee. That 30 amp heater fuse provides power first to the heater relay then to both the AC and heater blower motors, the blower resister and the blower speed control relay, it also feeds the 10 amp AC fuse, so i would start my testing with that 30 amp fuse.
If you have a lx450 or 40th anny or collectors maybe, you have a total of 4 a/c system amplifiers. All on the drivers side. Im going through this right now too. The gauge fuse is also included in the a/c circuit. What year and make is your truck?
So none of the indicator lights on the buttons light up? Did you check the gauge fuse?
have you confirmed the 40A heater fuse and 10 gauge fuse are good? the heater fuse supplies power to most of the system and the gauge fuse powers the coil for the heater relay which lets electricity flow to the a/c fuse and on and on.
Stupid gage fuse..... im done now...time to put the car all back together after taking it all the way apart. lol I love being ignorant and tearing my whole interior apart. lol. I at least did the 7 pin mod.
I wish my prob was only a fuse. Congrats
