No oil pressure
WA
Hey guys,
I just put my 1fzfe back together after doing the timing chain and getting the head overhauled. I started it up for the first time and I got no oil pressure on the dash. I've put an oil pressure tester on it and it's reading zero.
I've dropped the sump and checked the pick up which was fine.
I didn't torque the crank bolt when putting it back together, but surely I should get some sort of reading on the gauge?
Any help appreciated thanks.
The crank bolt needs to be torqued to 308 ft-lbs to make sure the oil pump functions properly. Both power steering pump and oil pump are driven without a keyway and require the proper torque for the clamping pressure.
Thanks for the reply ppc,
I'll get a torque wrench at it tomorrow and hopefully that sorts it out. I would have thought that might have caused it to be a bit low on pressure but didn't think it would result in no pressure whatsoever
your oil sending unit wire is been knocked off , hook it back up
My oil pressure light is on but I have oil in the engine bay hat. .I changed my oil pressure sensor and oil level sensor and it still reads low and my car doesn't not want to start. ..wat could the problem be???
If you read it said he put a gauge in and it read zero
I DID read it , and there is NO mention of the oil pressure sending unit or its wire connector
The gauge is in the dash Not the engine compartment
Your distributor isn't seated all the way down, the gear on the end drives the oil pump.
If you changed dist, you need to get the right length shaft and collar.
Maybe if it was an old Chevy 350 or Ford V8, the dizzy on a 1FZ is up high and driven off the camp with nothing else on it's shaft.
Hey guys,
He mentioned that he put a tester on it and it read zero. My understanding of that statement is that he was confirming the oil pressure sender operation by using a manual gauge in the engine compartment. That would be my first step, well maybe check the oil first!
Op just torque your crank pulley. Disconnect the ignition coil which will prevent the engine from starting and crank it over while watching your manual gauge.
Why did you think it was OK not to torque the crank bolt?
That was going to be my question too. Especially since it calls for a bit over 300 ft. lbs. and the pump engagement is dependent on it.
You don't have an oil pressure light, you have a low oil level light. Measure the oil level via the dipstick.
This is incorrect, the distributor has nothing to do with the oil pump.
The oil pump is driven by the shaft on the back side of the main crank pulley. Power is transferred by friction between the crank pulley shaft and the oil pump drive gear, this requires the crank bolt to be torqued to the 300 ft-lbs in order to work. No or insufficient torque = no friction or power applied to the oil pump gear.
