Bushing:
Outer Diameter = 33.01, 32.81, 32.98, 32.92
Side 1 Inner Diameter = 30.08, 29.97, 30.10
Side 2 Inner Diameter = 29.97, 30.09, 29.96
Length = 31.78, 31.72
Oil passage diameter = 7.71
Oil passage location = 13.62 hole edge to side 1, 10.02 from side 2 (13.62+10.02+7.71=31.36, little off length)
Shallow ~1mm oil galley around inner inline with passage
Outer 45deg chamfer, maybe 1mm (measured in length) around both sides
Doesn't look like any measurable inner chamfer
Block Hole Diameter: 32.85, 32.89, 32.84
Gear Bushing Outer Diameter: 33.01, 32.81, 32.98, 32.92
Thoughts:
I was concerned that some bushing outer dimensions were larger than block hole diameters. I double checked my measurements and they were fairly repeatable. The bushing does slide in and out of the whole.
