No heat! headgasket???
Lexington Ky
Ok I have a 97 that has over 200k miles. I don't know a lot of history. Ok I have pretty much no heat coming out of the vents. The truck runs at normal temp and doesn't overheat. The top hose and radiator feels hot. The heater hoses on the firewall are both getting hot and have tried to manually adjust the valve. The lower rad hose coming out of the thermostat housing is not hot and it's cool enough to grab with hand. The truck doesn't smoke or smell like burning coolant but after I drive the overflow tank empties. I have put my radiator funnel tool on there full of coolant and let run for as long as a hour. There are no bubbles or percolating that would make me think about a blown headgasket. Does anyone have any idea or help that could get me some heat and stop losing coolant. Thanks
Agree. Check your heater control valve, and also check your rear heater hard lines directly above the cats. If it's dripping there, it might just be boiling away, although you should smell it.
You could go to an autoparts store and get a head gasket test kit for peace of mind.
And Welcome to the forum @RoverGS ! :flipoff2:
I disconnected the heater control valve cord and moved it manually and it went from cool to cold. Both sides of the hoses by the valve are hot. The rear heat has been bypassed because I noticed the lines rusted through. Could the valve be bad but move freely and be hot on both sides?
Cool thanks for the links. I checked the servo motor and it seems to move fine when I got from hot to cold. I think I'm going to back flush the heater core and see if that helps. I still don't understand why the lower heater hose is not getting hot
It might be cool because no coolant is flowing in that circuit. May indicate an air block in the system---Do you have a high-point air vent you can use to burp the system?
I assume that you mean the lower radiator hose not heater hose. The flow path goes from the engine out through top hose of the radiator and back into the engine via the lower hose. Being only warm enough to touch means the radiator is functioning properly. There are three servos inside the heating unit that are most likely the problem. i.e. the one for the blend door.
I had the same problem, truck ran perfect temp, hoses hot, system burped, but puny heat. In the end, a good flush of the heater core did it. Did it myself and now I have 150F heat on the vents, where it would maxed in the 80s before.
Heater Core Flushing - OWNED!
