cabin heating problems
Fayetteville, NC
today was the first real chilly day so far this year down here in NC and i finally decided to get the cabin heating situation sorted out
back story:
my heater valve busted going over some train tracks this summer, just super brittle old, plus i had just done the PHH hard line bypass a few months earlier, so with the added stress the PHH side barb just snapped off...
no real big deal, went and got a oreilly because i needed it back together to get myself home from work and it was quick and easy and did it over lunch
i think i put it back together wrong, i believe i re-assembled it with the arm inside out, and it was closing it left to right instead of up and down... ANYWAY, i just assumed this was the reason i couldn't get the heat to work
now to what i've tried:
so i finally was watching under the hood to see what happened when the temperature changes on the HVAC controls, and noticed that when you flip it between hot to cold or cold to hot, the cable is not actuating at all... no movement under the hood whatsoever... i can just barely see under the dash where the arm is twisting from the drivers footwell, but i can't see where the cable is connected under the dash...
i'm thinking since i installed the arm wrong on the valve it's come loose under the dash somewhere from being over extended or something, does anyone know how it connects under the dash?
so after i took the arm off and put it back on what i think is the correct way (judging by a youtube video i found of the valve working) i at least have the valve opened manually...
so now that the valve is open, at least my rear heater works....
the dash vents are still blowing outside air though.... what could that be? is my dash core clogged? common problem? if so how is the best way to go about unclogging the dash heater core? easy to replace?
im having a similar non heat issue, looking under the hood when i change the temp control inside the car i can see the actuator move in and out, but the inside temp wasnt changing. did you figure out what was the issue w yours?
nope, i was sort of piggybacking off another thread here:
No Heat
i flushed my core and it didn't help one bit... now i can't see the motor actuating in drivers footwell, so i'm not sure what the problem is... searched in my FSM for the air mix servomotor troubleshooting and that came up with absolutely NADA...
but to follow up with the OP, i did have the little arm on backwards on the water mix... it's correct now, but now no cable movement when i change the slider... i think i've broken something but i don't know what it could possibly be... i may have to take the dash apart, and i'm REALLY not looking forward to that...
damn, glad to hear the core flush didnt do anything, may save me trying that first. checked rear heat this morn, also blew cold. hope to get into it over the weekend a bit to trouble shoot some more. ill update any progress, if you get anything fixed let me know
Not sure if this will help, I struggled with no heat all last winter and had no clue what to do until this past fall, tore into doing my own backflush of the core. I got about a pound of mud out of it this way, my temps went from low 80s on the vents to 150F. I realize now a shop may not do the full flush, or do a a little. Doing it at home with a few parts did trick, specially filling the core after flushing it to help avoid air entrapment in it:
Heater Core Flushing - OWNED!
if both are cold definitely check your water mix valve, tstat, coolant levels, etc...
AAA42, i think you hit the nail on the head, i think what you have is a problem with what your calling a "servomotor" we use to call them vacuum motors in GM cars. Anyway since the cable to the hot water valve on the fire wall isn't moving when you slide the control from cold to hot then you have a problem with your "servomotor"not receiving a signal to move. If Toyota's servomotors are set up like GM's were they run off of Vacuum lines, so i would look for a disconnected vacuum line. Oh one last thing, i have to agree with you about Toyota's FSM lacking in information, in some area's it's completely missing ANY info on systems your trying to trouble shoot.
I don't believe the blend door or heater valve work off any kind of vacuum or electric servo. I BELIEVE both are cable actuated but I know for sure they're not vacuum and the heater valve is certainly only cable actuated.
well, the cable is certainly actuated by a servo, but yes, i don't know that there is any vacuum involved... i just don't know where or how the blend door attaches.... i would also like to see a picture of someone with a working setup... a picture of the servo motor in the driver's footwell activating with the heat/cool toggle... just so i can see the range of motion
If I remember correctly (not driving my cruiser today, can't send you a pic), you can see the rod actuating by looking up in footwell, passenger side, just left of the glove box. A good light up and push the buttons on the panel, you should see the rod moving back and forth.
I have a LC and know the LX A/C and heater controls are a little different, but I believe the temp selector is basically the same and it is electro mechanical. The selector actuates an electrical servo that moves the cable in and out to actuate the water control valve on the firewall. You're probably going to have to gain access to that servo to check it out. The blend doors are electrical mechanical also.
so are the blend doors on a separate motor? or are they all on the same cable...
There are a number of servos (don't have my FSM with me, so I don't remember how many) and they are individualized (not mechanically connected to each other).
