No cdl switch???
ohio
I am looking at a 94 that does not have a cdl switch. Does that mean that the truck is not all time 4 wheel drive. I thought all the 80's were 4alltime. Could someone explain??
I bought a 94 which hadn't had one installed yet....easy as pie. You can get one from Cdan or Slee and the instructions to install are on Slee's website. Go ahead and do the Pin7 mod as well. It allows selectability in low and high range. Instructions for this are also on Slee's website. Be sure to specify year, as 93/94 is a different style switch from 95+
No, the 80 series is full time 4wd. The CDL locks the center differential. Without the switch the differential automatically locks in low range but not in high range. The switch and 7 pin mod allows a person to lock and unlock the center differential manually with the switch in both high a low range. Or run unlocked in high or low range.
Today I received the CDL switch from the Ebay seller in Mongolia. I think it was about $15 plus shipping.
thanks to all, i understand,
And if you want a cdl switch for cheap, let me know:grinpimp: I have some for sale and one specifically for 91 to 94 CDL switch that has "Center Diff Lock" written on the switch:cheers:
