On cold mornings (anywhere from -20 to +10 F) I'm having an initial period of no brakes. Pedal feels solid (almost too solid) but brakes barely work in the driveway. E-brake does work. After a few pumps they come alive and work fine. Problem only happens on occasional first morning starts, and not every time - but it's becoming more common.
In November I had a shop install the Slee SS lines and had the system flushed. Pads are at 50% and rotors are fine. About 4000 miles later I got the BRAKE idiot light and topped off the brake fluid reservoir. I assumed there was some air in the lines which worked itself out. No sign of brake fluid leaks.
Given that the brakes come back 100% after they warm up, I'm wondering if:
A: I have some air in the lines which somehow compounds the problem after sitting in cold temps. (but I negate this since they come back 100% in less than 5 minutes)
B: The pistons are gummy and not responding when cold. (But I don't think gummy pistons could stop the system from braking, if anything they would have trouble releasing.)
C: I've searched the topic and saw a correlation to loose wheel bearings, but again - since they come back 100% and this seems to be temperature related, I don't think is it a wheel bearing adjustment.
D: MC is starting to fail? The fact that they "self-heal" confuses me.
I don't trust anything mechanical that 'self-heals', and it's only going to get colder the next 6 weeks.
Any suggestions?
Any suggestions?
). This leads me to believe your issue is the fluid despite just having it flushed.
