Stock, there are only TWO leads that go to the battery MINUS post. A thick black lead that goes from the minus post clamp to the block and a thinner black lead that goes from the minus post clamp to the inside fender (next to the battery). Any other leads are your own or PO's doing...
The battery POSITIVE post has the thick cable to the starter motor and then the fusible link wires. Any other leads are your own or PO's doing...
cheers,
george.
For fusable link are you just speaking of the AM-1 MAIN black box with grey connector beside it? Or are you including with it a cable with about 5 ordinary blade fuses in a cluster going to the + post?
