SOLD NJ: H151 + HF1A + Parts for Conversion (80 series)
NJ
For sale is a H151 transmission with HF1A (part time) transfer case. When purchased, I was told it came out of a 2007 80 series. Included are almost all parts needed for the conversion. Missing is a center console and shift lever boot (58280-60041). Now included
Included in sale:
- H151 (LHD)
- HF1A
- 1FZFE bellhousing (LHD)
- Both driveshafts without the slip yokes (short end). You can reuse the ones from your US Spec 80.
- 1FZ-FE MT ECU (89661-60281)
- Wiring harness
- Brake Pedal + new OEM pad
- Clutch Pedal + new OEM pad
- Instrument Cluster for Manual (KM scale)
- Flywheel (new OEM Toyota)
- Input shaft bearing (new OEM Toyota)
- Clutch + pressure plate + bolts (new OEM Toyota)
- Release Bearing (new OEM Toyota)
- Release bearing fork + boot (new OEM Toyota)
- Clutch Release Cylinder (new OEM Toyota)
- Master Cylinder (new OEM Toyota)
- Hard clutch lines (mix of used and new OEM Toyota)
- Soft clutch lines (new OEM Toyota)
- New gear shifter (new OEM Toyota)
- Gear shifter knob (new OEM Toyota)
- Transfer case shifter knob (new OEM Toyota)
- Shifter console boots (new OEM Toyota)
- Cross member (used)
- Cross member rubber mount (new OEM Toyota)
- New OEM shift lever boot (58280-60041)
- Miscellaneous hardware, seals, boots, etc. (new OEM Toyota)
Located in NJ. Local pickup. Asking $8k
