Next Juncture Chasing Issue Down
Overland Park, Kansas
Website
www.guardianml.com
The background: '94 LC w/238,000k miles, US Model. Replaced all hoses with factory replacement material, same with plugs, plug wires, rotor, cap, EGR working, tested for leaks using starting fluid - no rise in idle at any point from the ether. I've run serious quantities of cleaner via the fuel, and premium, no improvement from any of this.
The problem: Cold start revs like it always has and settles down just fine, then......... after everything is warm and good, idle has dropped from 750 where its been for 14 years (I'm original owner) to 580 . Hot restart intermitently idles as bad as if I had multiple plug wires grounding, then clears up after driving 2 -4 minutes and goes back to idling normal as described above - lower than it should and just enough to be aggravating, but not bad enough to cause a permanent CEL. CEL coming and going at both hot restart as well as normal idle and is really bad about doing it when the temp outside is hot.
Tonight I will pull the tube feeding the throttle body and check for cracks, and maybe I'll just replace to be sure but it passed the ether test just fine.
The question: I've been reading threads here for two weeks and I can't really determine a single next path so I'd like some advice. I can argue for/against replacing/cleaning injectors - probably time, I've gotten my money's worth, but maybe they are fine...don't know how much involved in replacing them nor their as designed service life expectancy. I can argue for/against replacing all of the O2 sensors...don't know how many I have (think 4) and don't know how much work involved, but suspect this is not going to be cheap and wonder if I am prematurely pitching them as well. Suspect another next move for consideration is removing the throttle body but don't see a tutorial thread (I have FSM)and I wonder if one of the other moves is the right one.
Sorry for starting a new thread on this...sure it's been beaten to deathe but the 20 or so threads I've read don't really speak to my set of symptoms. I'm all ears guys.....you did me right and good on your front diff rebuild threads....coming back for more.:bang:
My first suggestion would be to pull the CEL code(s)...If the CEL is tripping then the codes should be stored, for awhile anyway.
I'm pretty sure there are just two O2 sensors and if they have not been replaced it sounds like you have gotten your $$ worth out of them.
Another thought might be something funky going on with the MAF (or whatever it is called on a '94).
Last thought would be chaffing on the wire bundle (proper name escapes me right now)...Do you notice the problem more while accelerating etc vs. sitting still?
Now you know where the $$ you were thinking of spending on a locker might be going :)
Maybe a wiring harness issue, back of engine bay, maybe heat makes it worse? Just a thought...
Good luck, sure does sound frustrating!
........Before you replace any 02 sensors visit your local Toyota service center. There was a recall on '93 & '94 02 sensors. They can run your VIN and see if you qualify - might save you some $ and aggravation.
You need to get the code for that CEL. '94s are OBD1 so you need the procedure and a paperclip:
Troublcodes.net Trouble Codes OBD & OBD2 Trouble Codes and Technical info & Tool Store. By BAT Auto Technical
I printed this procedure out for reference. I recommend you do it. Hopefully that'll be a good starting point for you.
EDIT: The illustration for the test plug is wrong. Orient the firewall to the left side of the illustration and that will give you the correct pins to jumper with paperclip.
Quote by me to you from another thread - in case you missed it:
https://forum.ih8mud.com/80-series-tech/328705-low-idle-start-up.html#post4942074
The harness on the firewall is covered in a metal sheild and it looks to be in great condition. I did have the O2 sensors replaced under the recall at about 140,000 so is it possible they are ready again? Let me use the info you provided to check the codes and I will come back to everyone.:bang:
Okay, I just used the cheat sheet my Toyota master mechanic freind gave me and I jumped the TE1 and the E1. The CEL blinks twice, then six times. 80t0ylc - the sheet appears to be the same thing you provided me (thanks for that - I picked p your email after I did the testing) The cheat sheet calls it a DTC no.26 Code and the summary indicates "Air Fuel Ratio Rich Malfunction". So, what does this newbie do next??????? Anyone?
The first thing a newb does is get the FSM so they have the proper information for working on the truck. It will have all the codes listed and the proper diagnostic procedure to find and fix the problem. The wiring harness that you were told to check is not the one along the firewall but the one that passes by the EGR feed pipe. Follow the wires from the firewall to the engine and you will see it pass next to a metal tube. This tube gets extremely hot and can, and has, melted wires. You need to check to make sure the wires in the location are sound. While you are in there buy some high temp insulating and wrap the wiring harness there to prevent any problems.
Well you got me curious and I broke out my FSM.
DISCLAIMER:
My truck is a 95 and is OBDII. The codes do not cross reference and I am looking to see if there is anything simple you can check without spending a ton of money.
I found a couple of codes in my FSM that could cause what you're seeing. The closest is fuel trim malfunction which will trip the CEL when the A/F ratio is detected to be too lean or rich. Possible culprits are a lose air intake hose, fuel line pressure out of spec, injector blockage (not likely since you're running rich) or injector leaking, 02 sensors, or engine coolant temp sensor. Its also says another culprit might be the mass air flow meter which you don't have, instead you have an air flow meter (just a different way of measuring how much air is getting into the engine).
Best place to start looking is to see if the intake hose is cracked.
Good luck.
I feel a little stupid - I have the FSM right here, I just hadn't cracked it open and I should have before I asked. Just thought someone might go "oh yeah - I know what causes that code and it's the ......" You said something though that makes me curious. If the intake tube feeding the thottle body is cracked, wouldn't that cause the motor to run lean since the air is entering the flow after the air meter (assuming the flow meter is what is plugged in just after the air filter cannister)? I tested the heck out of the tube with another can of ether and no change in idle - I'm heading out now to remove it to examine it, but regardless, tommorow I order a new one.
I posted for code P0170 for OBDII trucks, this covers both rich and lean conditions unlike your truck which apparently has individual codes for lean and rich. If you tested the intake tube and its fine, then its fine. Although you might want to bend it slightly around different axes to see if there are any visible cracks. If there aren't then its fine and don't waste you money. While you're at it, CHECK THE WIRING HARNESS where I described. Since you have the FSM read up on your code and troubleshoot before you spend any money. If you have any questions post here and people will help you.
I checked the tube, took it off and hand washed it. It is very pliable still and I did flex it maybe a bit more than necessary to see if it would crack or show light though it. Short of pressurizing it, it appears to be in great shape. The wiring harness comes from the pasenger side of the truck, then jumps the gap from the firewall to the back side of the motor right next to a tube than runs down the back side of the block. The wiring is in great shape and appears to be wrapped with a very rugged fabic oriented covering and it is in great shape and pliable as well. While I had the intake tube removed, I opened the throttle wide open and sprayed the throttle body and air hosed it dry. Looking with a flashlight, the interior of the intake manifold was dissappointingly dirty. I've NEVER allowed an air filter to get close to needing to be replaced. It must be from the PCV. I drove it after spraying it - no change. :crybaby:
You are right about the PCV valve causing your intake manifold to clog. Now take a deep breath, open the FSM, and read. Follow the instructions and report back your findings. Until you do this, there is no way for us to help you isolate the cause and help you fix it. We really need this info to help you.
I'll start readin' tommorrow. Thanks for the help so far.
I went back out and looked much more closely at the wiring harness and it appears I was wrong - there is apparent breakdown of the fiber wrap and the metal underwrap. How big a job is it to remove that harness to replair or replace? I will start searching threads to learn more but by first appearances, it looks like it could be a twister to get at all the end points to remove it. Maybe there is a better approach than removing the top half of the darned motor to get at everything. The ground bolt is secure and clean so I did not break it free - should I reconsider that?
Okay guys - did alot of my mechanical OCD processing last night and I have come to this. Before I go crazy (I delved into the manual big time last time Matt :) ) going through the manual effort of pulling and checking the components in the ECT, injector, and O2 circuits, Open E1 (Still can't figure out what Open E1 means), why not go directly to the source of my issue of the low idle and evaluate replaceing/repairing the step motor that controls the idle after I resolve the harness assuming the wiring is still good?
Update
Okay, the ECT is checked and replaced, the EGR testes out within spec, and the IAC checks out. Tommorrow I check the O2's. One question - what is the idle supposed to be - anyone know? I can't seem to find it in the spec's in the FSM yet. I am idling dead on at 600, but I recall it used to idle about 700 w/o air on.
IIRC spec is 650 +/- 50 rpms with air off and 800ish with air on...I know I've read the exact spec here on MUD before...
Your hood will tell you what the idle should be. Hopefully you have not had a accident and the sitcker was not replaced.
I did not see where you have tested the Throttle Position sensor or have cleaned the throttle body.
Check these two out.
