Next Juncture Chasing Issue Down
IIRC spec is 650 +/- 50 rpms ........
X2 - That's what my '94 FSM says (Page EG-24)
Your hood will tell you what the idle should be. Hopefully you have not had a accident and the sitcker was not replaced............
Sorry, Robbie! I looked at my '94 CA Emmisions hood sticker till my eyes crossed :rolleyes:(small print-tired eyes) and couldn't find the spec. It says "at idle" for timing adjustment - but never says what idle speed is:bang:. But the FSM comes through, again.
Concerning the wiring harness next to the EGR valve, it is possible to get to it w/o removing anything but it is a bit of a pain. I rewrapped mine when I replaced the head gasket and it was easy to get to while the EGR valve was out. Worse case scenario you pull the EGR valve to splice and rewrap the harness.
As of 20 minutes ago, the throttle body has been removed and cleaned even though it really was not dirty in the slightest. Not one vacuum port was dirty or clogged. However, the plenum gives me much stress as I could not see a way to really clean it up - freaking PCV valves! :mad:
The throttle position sensor was a booger to test and I am not confident of the results. I did re-set it per the FSM .020 feeler gauge - continuity, .030 feeler gauge - no continuity. The ohms reading did not go well so I cannot positively say the TP is good. Really, can someone give me the Cliff notes on what it does in the cycle of the system?
I checked the O2 sensor behind the cat and it passed the ohms test with flying colors. I have to read up on where the other O2 sensor is unless someone can tell me off the top of their head?
I cleared the 26 code to see if it reoccurs so we are back to relearning the idle. We'll see where we end up after 10-12 start cycles. I am going to have a friend loan me his portable O2 sensor so I can see if the mixture is as rich as I suspect it is. I think next up on the list is to find the other O2 sensor and test it. Then I'm off to the injector ciricuit to see if they al pass muster.
Again, what I am trying to resolve is a low idle and the 26 (rich) code. The ECT is replaced, the IAC is tested but not sure it is working on the first two steps, EGR working, throttle body removed and cleaned, TP sensor re-set, O2 at cat checks out, all new plugs, wires rotor, cap from Toyota, running the s*** out of Berryman's carb cleaner (3 cans first tank), next three will be run with premium.
F***, this is driving me crazy man. :bang:
Its a 94 and you have an O2 sensor behind the cats? Last I checked that only applies to OBDII trucks. You should have two O2 sensors in front of the cats. Someone has messed around with your exhaust and didn't put it back together properly. I'll look up what the TPS does later as I don't have my FSM on me.
As for cleaning the intake manifold the only way to do it right is to pull it and have a machine shop pressure wash it. Its quite involved however it may be worth doing as its restricting the amount of air getting to the cylinders. Actually shortly after I got my truck, before I started working on it, I was told that one of the runners was completely clogged and two of them partially clogged. If you do decide the pull the manifold get IdahoDoug's head gasket dvd as it will be extremely helpful in pulling the manifold. While the manifold is off it would be a great time to do the PHH.
Dang you Matt!!! :):) You're right like you already know you are. I was lying on my back upsidedown with my feet pointing the wrong direction on the odd day of the third week of the month. Da**it!:grinpimp:
Okay, so I found and tested ONE of the two O2 sensors and yes it was the one BEFORE the Cat. Where the heck is the other one? In good clothes before I went to dinner with the wifey, I looked with a flashlight from the exhaust manifold back the best I could without getting on the ground and I'll be darned if I see the other O2 sensor.
You know what I really think after all of this so far - I need a donor IAC to test on my vehicle. I still suspect that item and when I bench tested it through the four sequential steps, the plunger did not extend noticably the first two steps. The FSR calls for that to be the number 2 item after the ECT (replaced) and the dang thing is about $500. After the kids go to bed, I am going back down to tear into the harness to remove the heat shield before I wrap it with the header wrap. If I don't find a material issue there, I may just go ahead and order the step motor if I can't find someone locally to let me test their unit on my engine. Before I continue on to the next 20 items to check, you have any ideas for me Matt on how I can rule out the IAC?
This is very nice, I'll try to put one together!:bounce::bounce2:
We all have our days ;). There is one O2 sensor in front of each cat. Just look at the pipe in front of the other cat directly across from where the one sensor you tested is. The frame rail may be blocking your view which may be why you haven't found it yet. As for the other question, that will have to wait until tomorrow. I either have a head cold or really bad allergies and I can't think well right now. Anyone else reading this thread please chime in and try to help this guy.
Late last night I thought I posted this follow up, but this morning it isn't here, so here it is: I did the harness wrap last night and I cannot find visual or apparent damage to the harness wiring, so one more item checked off the list. I am about 8 start-and-drives post code clearing and throttle body cleaning and it is idling much more smoothly. Don't know why but it is. I beleive it has relearned it's idle and it is sitting at about 580 - 590 according to the dash tach. So, on to the next item to test.
How is this going? Sorry its taken so long but I got sick and then had a test to study for. I've been thinking about this and if you're running rich and you say your intake manifold is dirty them I'm guessing that the manifold is getting clogged to the point of causing problems. I say this because when you cleaned the throttle body you idle improved. What is most likely happening is that there is a constriction in the manifold that is causing the air velocity to increase which is decreasing the volumetric efficiency of the engine. If this gets bad enough I can imagine this causing the engine to run rich. The best thing to do is to pull the manifold and take it to a machine shop and have it cleaned. Since you have to pull the fuel injectors to do this this is a great time to get them cleaned as well.
Issue Resolved
Matt:
Sorry to hear you've been down. I hope it was not the H1N1. I've finally resolved my issue and I'm dissappointed I didn't try it sooner, but maybe others can learn from my mistake.
The O2's checked out, the IAC was not faulty, I changed the ECU so it's output is no longer in question, I replaced the ECT since checking it required removal anyway, I removed the Throttle body and cleaned it, I checked the intake tube, and I had already replaced all the hoses, plugs wires cap, etc. with OEM. My wiring harness is in great shape and is now insulated with header wrap.
After it was all said and done, I ran three tanks of premium along with THREE cans of Berryman's injector cleaner per tank which is about 60% more concentration than they call for and I now have a 700 RPM idle in gear that is smooth as silk! It was literally near the end of the third tank of fuel that it started just acting normal again.
The intake was not filthy by most people's standards. It just wasn't spotless so it did not meet MY standards. Yep - I have issues.
I appreciate you and MUD for the help and the brotherhood. Thank you for your help everyone!!!!!!!!:)
Congratulations on solving it!!!!!!!!!!!!!
:cheers:
