Newbie's first tune up
Arizona
I have had my 80 now for just over two years. I have put less than 5,000 miles on it in two years. Mainly for lack of time, gas over 4 dollars a gallon this year, andand having my AC go out last spring while living in Phoneix.
Two weeks ago my 80 turned into my DD. It will see 20,000 miles this year while I work full time and go through Paramedic School. (I'm bored with arresting bad guys). I had zero wrenching skills when I bought the truck. It didn't take long to figure out either needed to learn or shell out a lot of money to keep my rig running. Take care of her and she'll take care of you right?
Well today I set out to do my first tune up. The truck was running ok, but Im catching that bug of wanting to keep her in the best condition possible. After a few hours of wrenching I learned a lot about my truck.
I see now why this isnt made to go 85 mph down the highway. These truck were made to be made to be in the dirt. The tuna can, rubber boot around the distributer, and metal plate protecting the fuel pump where things I took notice of. I will no longer complain when I don't fly down the highway. Im content to do my 65 and knowing my truck is a tank.
I think I've almost got her base lined out. So for I've:
Changed the gear oil n both diffs.
Flushed PS fuild out of PS system, replaced with ATF
New Radiator/ New fluid
Filled ball joints with grease
Lubed drive shafts
New plugs
New wires
New Rotor
New Air Filter (K&N)
Tried like heck to chaged fuel filter/ no luck (having shop replace)
New Alternator and belts (neighbor the ex Toytota tech did that one)
Still on list to do:
Drain and fill tranny.
Change fuel filter
Run a can of Seafoam thru fuel system
Exchange brake flluid.
And anything else you guys can suggest?
I know some will flame me for going with the KN. But I noticed a difference. The orginal owner installed a hi flow cat, muffler and 2.5 pipe all the way back. With the KN it really breaths better now and sounds great! Then again it could be the 1/4 inch of silt I removed from the air box. The tuna can had even more!
The truck runs great now. I'm amazed how well it runs for 200,00 miles.
Next I need to drop the front drive shaft and lock the cen diff. My front Birfs are shot. But I have neither the time, $$$, or knowledge to tackle them right now. Got to fix the AC. That should be fun. Cant wait for that bill. So I'm going to run the truck in 2WD so they don't explode on me before I can replace them.
Two years ago I new next to nothing about vehs. Thanks to many of you and have learned a ton. Thanks for all your help, advise, tips, jokes, encourgement and expertise!!!
I did my plugs, wires, cap and rotor recently and man does it make a difference! One thing I did that wasn't on your list was to pull the valve cover( my gasket was leaking bad). I was sure glad I did because the spark plug tube seals were so old and brittle they just fell out of the valve cover when I pulled it off...:doh: This is all 1 :banana: stuff that really taught me alot about my rig and it runs a heck of a lot better. Did I mention the new fan clutch that I modded with the 6,000 cst oil? I love the sound of a ROAR in the morning....:cool:
Do I need to drain and fill the center diff with gear oil?
Ditch the K&N and call up CDan over at American Toyota and get yourself a factory drop in. I think you will find, most on the forum have very few good words for the K&N unit. Otherwise you have covered most of you basis. How are the brakes? If the pads need replaced, go with a set of 100 series pads. Much more wear resistant.
Otherwise, do a solid search of the FAQ section. It will shed a lot of light on things.
Good luck and happy driving.
I knew the KN would bring comments.
It usually does bring a few comments
I'd run some of the SeaFoam through your intake, and add adjust the tranny kick-down cable to the list.
You must be talking about the transfer case. Yes, you should drain and fill with new gear oil as well 75-90. I use Mobil 1 synthetic on all 3 diffs. I have done everything you had done lately and plenty more on the way now. Doing my front birfield repack now, man I forgot how messy it is since I did it 3 yrs ago. Some others stuff I would suggest you to do:
Rebuild starter.
Change PHH and all the cooling hoses, replace waterpump and thermostat.
Rebuild birfield before your birfield is mess up and need to be replaced. Get yourself a factory service manual it is not that hard, just time consuming and messy. You can even locate a rebuild dvd from one of the member on mud to guide you step by step of doing it.
Replace driving belts.
I see this in your list, when you do the tranny fluid drain and fill, I would suggest you drop the pan and clean up everything includes the filter. Mine was dirty when I took it out.
You probably have to clean your MAF once in a while since you use K&N the oil will stick on the MAF, could affect your truck performance over time. Get the CFC MAF cleaner t NAPA
Hope this help, good luck =)
I adjusted the throttle cable. No mork thud when I let off the gas. But now it idles fast at stops. Think I need to let it out a little. How much SeaFoam do I run through the intake? Intake = Crankcase where you add oil?
I wouldn't add SeaFoam to the crankcase. I put the better part of a can in there last month and ending up developing a very slight oil leak from the oil pump cover. I changed the oil and the leak has actually slowed somewhat. I believe it knocked at little bit of sluge loose and started to seep because of it. I do a couple times a year run some Seafoam through the throttle body via the large of the two PCV tubes. There are some write-ups on this if you do a search.
Good luck.
Can anyone tell me how I know wether I can just get away with doing the Birf rebuild/seals or if i need new birfs. I dont do heavy wheeling. More expedition type stuff. The birfs click when I turn hard.
You could swap them side for side and buy some time......... could you not?
I was hoping to not have buy new ones. I am also considering going with a a Part time 4WD to reduce wear. Wondering If I be better of with swap/repack with locking hubs or just buying new birfs? I dont wheel much.
P/T 4wd will cost you as much as new birfs. The birfs should last you another 200K miles or so.
P/T 4wd will also require that you get a different tcase and/or tranny. which will end up being much more expensive.
Sandcruiser Why do I need a new t case or tranny if I installed the manuel locking hubs kit? Slee has them for our trucks, says nothing of needing a new tranny or T/case Oh wait you dont have the 3FE. Bet your jealous.
You don't need a new T/C. You just need to take it apart, reconfigure it for PT4WD, and put it back together. Then install manual hubs.
All the info for that is on Slee's site.
:cheers:
Ok... I assume that it part of the kit, correct?
Part of *a* kit. Slee sells two kits, one with new T/C junk and hubs, the other with just hubs.
Whats the difference? One better than the other?
