Newbie with question
Hello all,
After months of search, I finally landed on a black 96 FJZ80 with 160k miles. The ride is incredible and the engine revs smoothly. May need a tune-up soon as there is a slight misfire at idle.
There is one problem, the hood has a big rust spot righ on the front edge (see pic). Now, I am not looking for a perfect paint job or anything because I am probably gonna put on a bug shield there later anyway. Is there any temporary and easy way just to prevent the rust from spreading? Again, I am not too concerned about the the way it looks as the area will be covered by a bug shield.
Thanks, everyone.
Frank
Take a dreaml and get to bare metal. Treat the metal with rust protectant and then paint over it. If your going to put a bug shield there, a mismatch of paint in that area won't be that noticeable. Make sure you layer the old and new paint at the edges so there is full coverage.
A rotary tool ie Dremel will help out a lot for this fix. Sand/grind until you see NO rust, just shiny bare metal. You may have to sand outside the obvious spot to get past the rust hiding under the paint. Once all rust is gone, use primer on all bare metal. A little base coat, then clear, and you're done.
Good luck.
I should have mentoned if you want it totally smooth you will need to use a thin layer of bondo or other. Not really needed if it is hidden. Your choice though.
Great advices from a great forum. Thanks, guys. I am gonna sand it down and do a DIY touch up job. However, the weather here has been cold and nasty (snow, ice, and sleet), and I don't have a garage that allows me to do the work inside. I may have to wait a few more weeks to get to my touch-up project. Do you think it's gonna get worse? Anything temporary I could do (like tape a protective cover)? Thanks again.
p.s. the truck is otherwise rust free (see pic).
Got any close ups of the rust spot? Is it affecting the integrity of the metal?
One other option; once you get down to bare metal (assuming you get all the rust out), you can use a self-etching primer, sand, then the regular primer, sand, then the paint, then clear coat, if you are going back to OEM look.
I have been looking at a similar scenario;I have no rust, but a few hundred stone chips and acid marks left from dead bugs. I've been planning on painting a strip a few inches tall across the nose, but using either 3M or SEM Chip Guard, same stuff they use on the rocker panels at the factory, it comes in smooth, fine, medium, or heavy texture, clear or black. Can be painted over, or sprayed over the paint and left that way.
Good luck, post pics
